Brake pads
acideraser
Re: Brake pads
Post by acideraser » Mon Apr 29, 2013 2:06 pm
Another question re rear pads - I believe for 3.0d I need pads for 320mm disk brakes. 345mm disks fitted to 4.0d or sd model?
P.S. apparently both textar and Pagid made by Tmdfriction
2011 X5 xDrive30d SE Platinum Grey 20" 336 alloys
Re: Brake pads
Post by X5Sport » Mon Apr 29, 2013 2:37 pm
Realoem shows 34216793247 as the rear disc part number for the 40d which is a 320mm*20mm ventilated disc.
The front one is 348mm*30mm, part number:  34116793244 on the 40d
Front 30d is a 332mm*30mm 34116793245
Rear 30d is a 320mm*20mm, part number 34216793247 the same as the 40d.
It looks like only the fronts are different.  No reference made to the trims, only the engines.
