Glow Plug Iocon
wpoll
Re: Glow Plug Iocon
Post by wpoll » Wed Jan 16, 2019 10:35 pm
Good idea but sadly the controller is mounted on the side of the block, under the intake manifold too. :x
Also, the controller is well known to fail. It has very fine wires between the circuit board and the output connectors. These wires are "welded" to the board terminals and these welds fail (vibration?). As the unit is glued shut AND the guts is "potted" (filled with sealant) it's not really serviceable by mere mortals, so it should be replaced too.
Testing the glow plugs may well show up a few dead ones, but due to their age, it's better to replace them all. And many folk have replaced all the plugs (or even just the faulty ones) and found they are still "dead" as the controller has failed welds. Back in they go...
I'm not normally a "replace everything on spec." kind of guy - I try to keep stuff going as long as possible - but in this case, nothing else makes sense. :thumbsup:
Paulpen
Re: Glow Plug Iocon
Post by Paulpen » Wed Jan 16, 2019 11:02 pm
Blows my idea to pieces then :cry:
wpoll
Re: Glow Plug Iocon
Post by wpoll » Wed Jan 16, 2019 11:08 pm
BMW are good like that... :D
Re: Glow Plug Iocon
Post by Leslie » Mon Feb 18, 2019 4:08 pm
Good useful thread , my coolant temp is 65 to 70c on my e70sd so I think my glow plugs are dead as they will have been running constantly, definite vibration as if its off a cylinder when it gets below 2c and struggling to start first time at -4c.
New thermostats being ordered to start with ! :D
