BMW scanner 1.4
Re: BMW scanner 1.4
Post by X5Sport » Sat Jan 29, 2011 2:56 pm
Facelift E53 3.0d under bonnet.
Webasto Unit is on the right hand side of the image. Opposite side to the washer bottle.
nujon
Re: BMW scanner 1.4
Post by nujon » Sat Jan 29, 2011 5:01 pm
Thanks X5Sport - yes I've got one - I had clocked it earlier but didn't know what it was (obvious once it's pointed out!) - I presume as standard UK config, this fires up automatically on starting the engine if the outside temp is low/near freezing. ? The manual refers to the Telestart option - is fitting this a DIY option does anyone know?
fenj66
Re: BMW scanner 1.4
Post by fenj66 » Sat Jan 29, 2011 5:07 pm
yes, telestart is a retrofit option but costly i believe.
other options are to make your own remote control or add the aux heat function to the obc which gives you a timer to set the heater to start next morning.
there are other threads about this on this forum. have a good look around using the search option and see what you think. :)
nujon
Re: BMW scanner 1.4
Post by nujon » Sat Jan 29, 2011 5:16 pm
Thanks fenj66 - are you saying that the necessary kit/software to control the aux heat function from the monitor is already present and just needs to be enabled via a scanner?
marlin758
Re: BMW scanner 1.4
Post by marlin758 » Sat Jan 29, 2011 5:38 pm
Hi - like fenj says the auxiliary heat can be enabled via a scanner . This gives you the option to turn on the Webasto via the OBC , manually or by a timer i think.
If you want to turn it on remotely ( while you sip your coffee in the morning ) you then need the Telestart unit ( Approx £150 I think ).
The third option is the DIY one . i have done it and it works fine . See the link below for an excellent writeup by monkeyfinger .
viewtopic.php?f=22&t=445
55 3.0 D Sport - Silver - Black leather - Carbon fibre badges - Rear view camera - Webasto remote control modification, HID Headlamps and all the rest are LED's.
nujon
Re: BMW scanner 1.4
Post by nujon » Sat Jan 29, 2011 6:47 pm
[quote=""marlin758""]Hi - like fenj says the auxiliary heat can be enabled via a scanner . This gives you the option to turn on the Webasto via the OBC , manually or by a timer i think.
viewtopic.php?f=22&t=445[/quote]
Thanks Marlin758 - investigating just now it looks as though the Webasto in my car does not work - the unit, valves and exhaust look brand new and there is no sooting inside the exhaust outlet - are these heaters totally (software) disabled for the UK market do you know?
Re: BMW scanner 1.4
Post by X5Sport » Sat Jan 29, 2011 7:13 pm
If you connect a lead to the 12v starter point at one end, push a sewing needle carefully into the Green/White wire on Pin 1 of the webasto and touch the wire to the needle the Webasto should fire up and keep going for as long as you keep that connection in place. Putting 12v on Pin 1 will (should) switch the unit on, which is how the DIY version works.
In normal operation the Webasto only comes on below 5C, and the Auxiliary Heating mode requires a good battery and sufficient fuel. :D
The unit is normally enabled as a coolant heater in the UK by default. Full auxiliary heating was enabled if you paid for the Telestart option at new, or had it retrofitted.
nujon
Re: BMW scanner 1.4
Post by nujon » Sat Jan 29, 2011 7:48 pm
Thanks X5Sport - I'll try the wire test tomorrow
marlin758
Re: BMW scanner 1.4
Post by marlin758 » Sun Jan 30, 2011 9:17 am
Keep the 12 v on for a minute or two - when I checked mine I was convinced that the Webasto was faulty as it seemed to start up then shut down. It appears to go through a purge sequence first .
It sounds like a fan starts up , runs for a short while and then stops . Then after a short while it goes through its fireup sequence .
evoblue
Re: BMW scanner 1.4
Post by evoblue » Sat Feb 05, 2011 11:19 am
Thanks for the reply's. I have changed the alarm disarm flash to on, heater so the timer works (dealer said it couldnt be done) and did try the american lights on during the day. I will look throught the other menu's.
ChewingBacca
Re: BMW scanner 1.4
Post by ChewingBacca » Sat Feb 05, 2011 12:24 pm
[quote=""evoblue""] and did try the american lights on during the day.[/quote]
Careful with that one, IIRC that is the high beam. EU is the HID's.
Would like to have had DRL on the halo side markers but this is not possible.
evoblue
Re: BMW scanner 1.4
Post by evoblue » Sat Feb 05, 2011 3:12 pm
I have taken the american lights back off as you say it was the high beam not the side lights. There was another but I never tried it. will see when I get a chance.
love154
Re: BMW scanner 1.4
Post by love154 » Sun Feb 06, 2011 9:03 pm
hi am looking to get one off these can i chance the pdc settings with this. also what other functions can i change. tv in motation?
thanks
lordviper
BMW scanner 1.4
Post by lordviper » Sun Feb 06, 2011 9:21 pm
Yes tv in motion is possible from what I have read I'm just trying to figure out where the scanner would connect?
And which one is the best to buy?
Any help is appreciated.
nujon
Re: BMW scanner 1.4
Post by nujon » Tue Feb 08, 2011 9:04 pm
[quote=""fenj66""]i bought one in december and added aux heat/tv in motion/flash indicators on alarm activation/changed parking sensors distance alerts.
however! i bought mine on ebay from a seller called amar_87 and after new year it stopped working. i have contacted the guy and sent it back for repair but to be honest, the communication from the guy is awful. i still havent had it back or heard anything.
seeing as how these scanners are getting more popular now, i wondered if anybody else has had issues with theirs or this seller?[/quote]
Just read this - see my post on the other scanner thread = same seller !!
