Running boards needing cleaning? Good deal?
Sanj
Re: Running boards needing cleaning? Good deal?
Post by Sanj » Fri Mar 25, 2011 8:45 pm
I'm joking you cheeky bugger! How's the remote? Ordered? Weekend nigh, weather good, no excuse! Apologies :hijacked:
X5-MK
Post by X5-MK » Fri Mar 25, 2011 9:49 pm
Costco are doing 5L wonderwheels for £7.49 :thumbsup:
BMW X5 4.6iS V8 SPORT
Sanj
Post by Sanj » Fri Mar 25, 2011 10:05 pm
Oh man - change the avtar!
I'm not paying attention again!
X5-MK
Post by X5-MK » Sat Mar 26, 2011 1:33 am
Sanj matey, how's the remap going?
Will probably give Jason a call to book it in for August (Only time I can get time off and that's on a Saturday.
x555
Post by x555 » Sat Mar 26, 2011 8:21 am
getting back on topic though it is hard to concentrate with that avatar :heat: :hooters: :poke:
here are mine before and after using wheel cleaner....
X5-MK
Post by X5-MK » Sat Mar 26, 2011 12:50 pm
Looking good x555 :thumbsup:
How long did you leave this stuff on before washing off?
x555
Post by x555 » Sat Mar 26, 2011 1:36 pm
[quote=""X5-MK""]Looking good x555 :thumbsup:
How long did you leave this stuff on before washing off?[/quote]
Leave it soak in a good few mins then give it a good rubbing in then hose off.IIRC i think i did it a few times to get best results :thumbsup:
Rintintin
Post by Rintintin » Mon Mar 28, 2011 9:44 pm
Gents a tip the wife let me into is Tooth paste is good at getting these things clean apparently its an old housekeeping tip for getting rid of rust.
Rusty
Post by Rusty » Mon Mar 28, 2011 9:48 pm
[quote=""x555""][quote=""X5-MK""]Looking good x555 :thumbsup:
Leave it soak in a good few mins then give it a good rubbing in then hose off.IIRC i think i did it a few times to get best results :thumbsup:[/quote]
When I did mine, I used an old piece of scotch brite with the wonder wheels which really helped in removing stubborn marks.
Runabout - E92 3 Series Coupe
exfive
Post by exfive » Fri Apr 01, 2011 12:04 pm
Hi just a heads up, I bought the 5l bottle of wonder wheels from costco last week for £6.ish, not sure of the exact price as I threw the receipt away.
tombs
Post by tombs » Fri Apr 01, 2011 12:21 pm
I’ve heard just normal bottled water especially evian bottled water really works, it’s to do with the mineral content which molecularly works at an atom level liquidising any stains and pitt marks. Go on try a bottle… :thumbsup:
BL02WAS
Post by BL02WAS » Fri Apr 01, 2011 12:33 pm
tescos wheel cleaner 2 quid for bottle, did the trick last week!!
centurion
Post by centurion » Fri Dec 12, 2014 3:42 pm
quickie... can I apply the cleaner with boards on the car or would you suggest removing the boards as cleaner could damage the paints/plastics etc? any hints?
Post by X5Sport » Fri Dec 12, 2014 8:04 pm
Just put masking tape along the bottom of the doors to add a bit of protection and if you can, avoid splashing cleaner on the paint. It will depend upon how acidic/alkali the cleaner you use is.
If it's only on for a short time it should not do damage to any waxed paintwork.  I put bilberry cleaner on with a softish brush and that seems fine.
