DAB Retrofit to X5 2010 E70
damiandavis
Post by damiandavis » Mon Nov 16, 2015 1:46 pm
Looking into the costs of adding DAB to my X5 2010 plate car with Professional NAV etc. Spoke to a BMW dealership who have quoted £550 ish for supply, install and coding of a BMW DAB controller + remote (but not a remote) + DAB aerial replacement for existing FM aerial.
Had a look on Fleabay and found a few units stated as compatible - http://www.ebay.co.uk/itm/BMW-E81-E88-E90-E91-E60-E61-E63-E64-E84-E70-E71-DIGITAL-DAB-TUNER-MODULE-9176958-/171718316271?fits=Car+Make%3ABMW%7CPlat_Gen%3AE70&hash=item27fb3590ef:g:OwUAAOSwBahVAtmM
Question is - does anyone have experience of performing a retrofit - if so is it achievable assuming you can get the coding handled?
Does anyone know what part number the aerial replacement would be?
If its at all DIY capable then i'd be interested in doing it myself and saving the £300 in labour charges.
Damian
Re: DAB Retrofit to X5 2010 E70
Post by Horizon » Mon Nov 16, 2015 6:18 pm
damiandavis
Post by damiandavis » Mon Nov 16, 2015 8:33 pm
Thanks. Yes i saw that, and got the same parts quoted by BMW. Confusion abound as the service dept told me that i wouldn't need to use the remote provided with the system and it would be as if installed as a factory option. Seems that this is not the case from looking at the youtube vid about the unit. really just wanted to get the factory dab module 2nd hand, connect and get coded.
Any suggestions for an independent supplier / fitter that could do this job would be appreciated.
shadrack
Post by shadrack » Mon Nov 16, 2015 9:20 pm
It amazes me how dab is still not a standard on all cars and it should of been for years now
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Post by X5Sport » Mon Nov 16, 2015 9:34 pm
Indeed.  Even Skodas get it standard now.... :D
BMW want to charge for every little thing and because people buy them, they can.  They probably aren't alone in that though.
damiandavis
Post by damiandavis » Tue Nov 17, 2015 7:20 pm
So scores on the doors for my DAB quotes
BMW specialist independant - £299 fitted - autodab style FM break with remote solution
BMW dealership - £560 - autodab style FM break with remote solution (although he says i don't need the remote)
Parts quoted :
  • 65.12.2.336.500 = DAB retro- can bus unit
    65.12.2.337.891 = Antenna
    65.12.2.337.892 = Remote
CarTronics - £900 est for an emulated solution that is not FM based, but they haven't responded to clarify to me how it works..
Outside of that a quick search on fleabay show up allegedly compatible DAB modules for around £200 - http://www.ebay.co.uk/itm/BMW-E81-E88-E90-E91-E60-E61-E63-E64-E84-E70-E71-DIGITAL-DAB-TUNER-MODULE-9176958-/171718316271?fits=Car+Make%3ABMW%7CPlat_Gen%3AE70&hash=item27fb3590ef:g:OwUAAOSwBahVAtmM
Which doesn't ref the additional components required - e.g. aerial modification, CAN connections, Coding etc.
Ideally my choice would be to buy a 2nd hand BMW module for the CIC and get a man with a plan to fit and code, however this seems challenging to find... Cartronics seem v.pricey so reluctant to go that way.
Again if anyone has any experience of the CIC module route and specialists to fit it would be great to hear.
DD
jason909
Post by jason909 » Thu Nov 19, 2015 8:39 pm
Hi,i have had a quote of £600 fitted that will give me the factory look not using the fm signal,that was from a Manchester based company,hope this is helpful.
damiandavis
Post by damiandavis » Thu Nov 19, 2015 8:51 pm
interesting - did they give you an indication of the solution? emulated? head unit swap?
diluxe
Post by diluxe » Fri Nov 20, 2015 12:07 pm
i have dab in my 2012 and although the sound is great when it locks in a signal, the constant drop outs meant i switched back to FM within the 1st week of owning the car.
damiandavis
Post by damiandavis » Fri Nov 20, 2015 6:48 pm
Ah, the beauty of DAB. I have the same with my FM tuned Pure Highway. Gives me access to RadioX and Talksport.... sometimes... ::)
jason909
Post by jason909 » Wed Nov 25, 2015 7:40 pm
Hi,yes it is some sort of emulator it will appear just like factory on the idrive,only downside is a little ariel on the window,i think it is the same one cartronics are selling,the company is Safe & Sound in droylsden manchester 01613704751,going to get mine done in january,you could wait and see what it looks like then before you take the plunge.
damiandavis
Post by damiandavis » Sat Nov 28, 2015 9:52 pm
sounds good. i'll watch the thread and see what you think of it.
jason909
Post by jason909 » Mon Jan 04, 2016 1:00 pm
Hi,took the car in this morning to have the dab fitted,should get it back later today,but it might need coding in so will wait and see will post some pics of how it looks when i get it back.
jason909
Post by jason909 » Wed Jan 06, 2016 10:24 pm
Hi,got the car back today it looks just like the factory setup just got a small ariel on windscreen,havent had it drop the signal yet,it does have to be coded in but they took care of that,im very happy with it,will put a couple of pics up tomorrow.
jason909
Post by jason909 » Wed Jan 13, 2016 11:56 pm
Hi,here are some pics sorry for being sideways can't figure out why it uploads like that.ImageImage
