NEW Reverse Camera Issue, anyone seen this Wiring?
Zakbelle
Post by Zakbelle » Mon Jul 07, 2014 8:45 pm
Hi I went and bought an XTRONS CAM009 reverse camera after sending a previous one from another company back as it was very dubious quality. This one looks good quality but has a very bizarre wiring system. I was going to use the wiring diagram as posted on here by Sanj previously but the wiring for this doesn't appear to allow this. I was going to remove the RCA connectors as normal and use the screening but the cables are not screened but two core cable instead. Okay this isn't an issue as I can find out which is +ve & -ve BUT if you can see on the diagram the 5M RCA video extension cable has an extra cable to connect to the reverse switch on the display unit?
Can I just connect the +ve from the camera power cable to pin 14 on the white TV module connector and the -ve to Pin 13, then connect the +ve from the camera video RCA plug to pin 1 on the blue TV module connector and the -ve to pin 10 and 30 & 86 on the relay?
http://i1373.photobucket.com/albums/ag3 ... 8247a4.jpg
Any help would be appreciated
Craig
Re: NEW Reverse Camera Issue, anyone seen this Wiring?
Post by Greydog » Tue Jul 08, 2014 5:13 pm
Hi Craig
If you are using Sanj's drawing.
Pins 13 and 14 on the white plug are RCA connections 13 pos (Centre Pin) 14 neg (Outer ) you could splice in an Female RCA connector to make it a simple plug in connection. Looking at your Camera instructions cable 1&3 are joined 4 goes to pin 10 on the Blue plug or 30 on the relay 5 is connected to Pin 1 on the Blue plug or 85 on the relay Pin 17 is a Negative trigger for your monitor fed from 87 on the relay (I am assuming you have the OEM set up) so cable 2 isn't needed as far as I can tell.
Hope this of help
