Which scanner / OBD software should I buy?
RRH
Post by RRH » Wed May 07, 2014 11:14 am
Hi all,
Sorry if this has covered many times; I did a search and couldn't find anything recent.
At 160k miles, my car has some niggles... The PDC and remote lock haven't worked for ages, it appears to have bluetooth but I've never quite figured it out, and I've never had the aux heating working since I bought it at 30k miles.
I'd like to check out / reset whatever codes are showing, and also enable things like auto door locking.
What do I need?
Simon :)
Steamyrotter
Re: Which scanner / OBD software should I buy?
Post by Steamyrotter » Wed May 07, 2014 1:18 pm
Depending on how far you want to go....
BMW Scanner 1.4
Carsoft
Autologic
INPA
DIS / GT1
NCS Expert
WINKIP (not recommended........Very easy to brick your car apparently)
Progmann
Dealer
RRH
Post by RRH » Wed May 07, 2014 2:15 pm
Just to check codes, reset, and enable bits that might be interesting!
Raj
Post by Raj » Wed May 07, 2014 8:54 pm
Scanner 1.4.0 is the more common as it's cheap and tends to do what you are asking.
The others may offer more functionality but are more expensive I believe.
I have the tyre pressure warning permanently lit at the mo but the scanner doesn't bring it up for some reason...
RRH
Post by RRH » Thu May 08, 2014 8:22 am
Thanks for that :)
I realised I had bluetooth for the first time yesterday (owned it 6.5 years / 130k miles) - I thought the button was just standard fit and the module wasn't actually there...
I managed to accidentally put the temp in to F, too, when resetting the service light! Doh!
Steamyrotter
Post by Steamyrotter » Thu May 08, 2014 12:47 pm
I am beginning to wonder if letting you loose with some software would be a good idea???.... O:-)
lol
RRH
Post by RRH » Thu May 08, 2014 12:59 pm
lol
Post by X5Sport » Thu May 08, 2014 2:58 pm
Software + Novice =
simontaxi
Post by simontaxi » Thu May 08, 2014 4:20 pm
Does anyone have a link to the  / OBD software for 08 plate e70 x5
bmw x5 3.0 sd 08 plate
