Gearbox error code
kamb
Gearbox error code
Post by kamb » Tue Mar 25, 2014 12:26 pm
Took x5 in for smoking issue
Upon the scan it had error code for gearbox something along lines
- oil deteriorated
- level to high
- permanent
I have had no issues with the gearbox and it drives fine
Any ideas what to do?
Re: Gearbox error code
Post by X5Sport » Tue Mar 25, 2014 12:33 pm
That's going to be one of these 'do I, don't I' debates.
To me that indicates the oil is going bad and perhaps it may have been changed and the box was overfilled.
The only was you are going to know is to see what colour it is.  If it's brown and cloudy then it's pretty much had it.
kamb
Post by kamb » Tue Mar 25, 2014 2:57 pm
Whats the best way of checking it? Car only
Done 73k miles
Post by X5Sport » Tue Mar 25, 2014 4:16 pm
You need to get underneath with the car level.  There is a proper procedure that needs to be followed which includes the temperature of the oil before you measure it.
'Sealed for life' really only means 60k miles if BMW are to be believed.
kamb
Post by kamb » Wed Apr 02, 2014 5:31 pm
Ok guys scanned with bmw 1.4 tool today and got following error
54c6 oil abrasion
This code was deleted before and has come back
I'm guessing its a simple tranny oil change?
What's the best oil to use and how many litres?
On last thing do I need to get adaption levels changed after?
Raj
Post by Raj » Wed Apr 02, 2014 6:02 pm
Yes it is an oil change required but you do not need to readapt the gearbox after.
kamb
Post by kamb » Wed Apr 02, 2014 7:15 pm
Cheers Raj
How many litres are required?
Is it defo the gearbox oil
Or the transmission box oil?
It can up
In the VTG sub menu on reader
Raj
Post by Raj » Wed Apr 02, 2014 8:51 pm
I use the scanner 1.4.0 software so the error is logged under the specific unit. So mine came up under the transfer box module.
If it's gearbox I believe it's something like 8 litres ish. The transfer box only takes 1 litre.
kamb
Post by kamb » Thu Apr 03, 2014 8:25 am
Is the transfer box menu different to gearbox menu on scanner?
I'll check again to see which module it was in from what I can remember it was VTG
kamb
Post by kamb » Fri Apr 04, 2014 1:06 pm
Can anyone provide genuine BMW oil product number?
Is it 83 22 0 397 244
Raj
Post by Raj » Sat Apr 05, 2014 3:17 pm
[quote="kamb"]
Just checked mine unde the scanner and VTG indicates the transfer box. So that is the one litre BMW stuff which I think is the one you have stated above. Only needs the one bottle as it's about £30ish.
Also worth getting the 2 washers for the drain and fill plugs.
kamb
Post by kamb » Sat Apr 05, 2014 4:08 pm
Cheers Raj
BMW Indi quoted £90 to do it
Thought I would ring BMW dealership they quoted £75 so
Probably get them to do it.
Back street garage said do it for £55 but they don't have software to
Update values etc
Steamyrotter
Post by Steamyrotter » Sun Apr 06, 2014 9:50 pm
If you try anything like that yourself...  Always undo the fill plug first before the drain plug...
Means you don't empty the fluid until you know you have a means to fill it again..
Raj
Post by Raj » Sun Apr 06, 2014 11:49 pm
[quote="Steamyrotter"]
Good advice. Also the drain and fill plugs are both horizontal on so you need a pump to refill the box.
kamb
Post by kamb » Sun Apr 13, 2014 10:57 am
Booked in at BMW dealers for next week £75 not bad as oil cost £33
