Crankcase breather removed as per BMW tech bulletin (?)
ArthurSleep
Post by ArthurSleep » Thu Jan 09, 2014 12:32 pm
Hi all, I've had my '55 plate 3.0d in for a Inspection 2 at a local BMW specialist last month.
A few of the usual things to be done.
I asked them to check the breather as it was on my mind after reading a thread about it on here a while back.
They did & reported it was badly clogged. Instead of a replacement, they told me BMW's latest advice (via a technical bulletin) was to remove them altogether in E53's. Which they did.
I had a look on here but couldn't see anything mentioned regarding this.
Can anyone shed any light or confirm the above. Not what I was expecting. See attached pic of the paperwork that came back from the garage.
Re: Crankcase breather removed as per BMW tech bulletin (?)
Post by X5Sport » Thu Jan 09, 2014 1:03 pm
Interesting.  I assume they remove the actual breather and refit just the cover then?
I thought the idea of it was to remove oil from the fumes, but if not then what is it doing, and why fit it at all if it appears that it isn't needed?
The wording is a little ambiguous and it would be handy to get a look at the TSB for that.....
fenj66
Post by fenj66 » Thu Jan 09, 2014 1:05 pm
thats interesting!
i replaced my foam type with the newer sort without issue. although the newer sort didnt look like it did much anyway, just a hollow tube.
might be worth finding a bmw indie and getting their thoughts..
ChrisLux
Post by ChrisLux » Thu Jan 09, 2014 2:57 pm
I was talking to an Indy about this on Monday and they told me that if you order a breather for an E53 from BMW now , it comes only with the breather body but NOT with the toilet roll shaper filter that normally fits
around it , yet if you order the same for an E39 then you get the toilet roll in the pack too .
LincsX5
Post by LincsX5 » Fri Jan 10, 2014 10:21 am
Anyone got access to this TSB? I was going to do my breather and air filter this weekend but will hold off until I've seen further info.
2008 E70 3.0D SE Dynamic kit
2006 SAAB 9-3 Aero
2004 E53 3.0D Sport. Heated steering wheel, Remote Aux heat, Arches, Skid plate. SOLD
2002 E46 318Ti SOLD
1972 Triumph Spitfire
khuram-23
Post by khuram-23 » Tue Jan 21, 2014 7:26 pm
i am in the same boat, i want to do my air filter and have read a few threads so i am thinking of replacing the breather but not sure if i need to order the case or the vortex part and just swap it out?
any part numbers from bmw would be appreciated.
thanks
Caesium
Post by Caesium » Tue Jan 21, 2014 9:21 pm
Its just the top, it bolts on to the existing housing.
The existing separator assembly is removed and discarded, I think this is what the stated procedure is referring to.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
khuram-23
Post by khuram-23 » Tue Jan 21, 2014 10:39 pm
:) thanks for that will be at the garage this week for service so will pick it up, hopefully not too expensive.
ArthurSleep
Post by ArthurSleep » Wed Feb 05, 2014 6:18 pm
Bumping this back up.
Can anyone shed any light or direct me to where I can view this BMW tech bulletin?
Caesium
Post by Caesium » Sat Feb 08, 2014 9:39 am
You shouldn't need the tech bulletin to change the breather for the updated one, it's a very simple job.
No offence but if you need to refer to the bulletin, them maybe leave the job for someone else?
This is all based on the assumption that the breather mod is the updated housing lid, as this procedure is essentially a removal and discarding of the original lid and replacement with an updated version.
Unless anyone knows of any other procedure
Currently :
Previously :
2004 BMW E46 M3
The list goes on...
fenj66
Post by fenj66 » Sat Feb 08, 2014 6:00 pm
i didnt think OP was thinking of attempting this job himself, merely asking for some sort of confirmation that the dealer wasnt talking absolute bullshit ( as they most often do!!) and actually had a genuine bmw guidance plan to remove it in the first place. something i wouldnt mind being privvy to also.  :)
John
Post by John » Sun Feb 09, 2014 8:45 am
I went to my local BMW dealer yesterday to buy a crankcase breather kit/thing, I was given what I believe to be the "old" style thing with toilet roll type filter etc, I do hope I havnt been ripped off...... :'(
02 X5 3.0D Sport
Post by X5Sport » Sun Feb 09, 2014 11:57 am
That's the old version.  You need the vortex one.
John
Post by John » Sun Feb 09, 2014 12:14 pm
will the old version do a turn til next time I change/clean it etc?
02 X5 3.0D Sport
Post by X5Sport » Sun Feb 09, 2014 12:27 pm
Yes.  It should last several thousand miles with no issues.  :)
I changed the one on my '04 E53 when it had about 46k miles on it.  It wasn't looking good by then though.
R
