Antenna
Posted: Sun Dec 08, 2013 5:58 pm
by aldmc
Hi,
In investigating Bluetooth upgrade options I have an antenna I think stuck to nav unit
Any ideas what it does it's wired to radio units under lpg tank?
Re: Antenna
Posted: Tue Dec 10, 2013 7:54 pm
by mennie
Doesn't look like anything that I have in my car.
Do you have any phone option installed at the moment?
I used the instructions on bimmernav.
Re: Antenna
Posted: Tue Dec 10, 2013 9:11 pm
by Horizon
Could it be a DAB interface unit
Re: Antenna
Posted: Wed Dec 11, 2013 7:43 am
by aldmc
Doesn't seem to be any DAB anywhere, I thought maybe Trafficmaster? It does have the button on the dash.
I am probably going to go down the cheap route of using the inbuilt Motorola until I have the tank out at next service
Re: Antenna
Posted: Wed Dec 11, 2013 1:17 pm
by Steamyrotter
looks like the Bluetooth one...
Trace cable back.
Bluetooth modules usually fitted to the front bottom of themounting plates below the CD player.
It sits at an angle and you can see it poke up by the plastic piece under the boot floor....
Re: Antenna
Posted: Wed Dec 11, 2013 7:42 pm
by mennie
If that was the Bluetooth antenna, it's supposed to be on top on those 2 screws sticking out.
Also the Bluetooth antenna uses very thin RG-174 coax cable with a FAKRA plug.
Re: Antenna
Posted: Thu Dec 12, 2013 12:39 am
by Steamyrotter
true..
Didnt zoom on the piccy enough.
Not seen one like that either.
you will have to do it the hard way and trace cables back to source
Re: Antenna
Posted: Thu Dec 12, 2013 8:01 am
by Jayx5
It might be traffic master as ive got it in mine.
Re: Antenna
Posted: Thu Dec 12, 2013 8:44 am
by aldmc
Thanks guys
