frozen doors !!!
Mole
frozen doors !!!
Post by Mole » Sun Nov 28, 2010 9:20 pm
just a quikie,
i guess everyone is suffering the same bad weather at the moment ! but didnt know where else to turn, the x5 is sound but less than 2 weeks ago i bought a golf tdi ( s reg 98 plate 1.9) ( a run around and for back an for to work as the mrs is using MY real car ) but i kid you not i cant turn my back on it the last 2 days without the doors freezing ! it will unlock but just cant budge the doors, i left it half an hour earlier came back and just could not open it ! i lost a handle on the x5 last winter so didnt want to pull to hard ! any tips or advice !!!
mole :thumbsdown: :thumbsdown:
millerman1ac
Re: frozen doors !!!
Post by millerman1ac » Sun Nov 28, 2010 10:24 pm
pooped myself on sat morn before my trip went out to car and it was frozen pulled the handle, door opened but handle stayed out!!
omg i thought tried to shut the door it wouldn't!!...shit i thought, jumped in and pulled the door tight and locked it, the door stayed shut...
climbed out the passenger side, just hoped i didn't break it...
later............after a while driving it arround had the balls to try it again and all was fine ;o)
phew!
any ideas how to stop it freezin?
2004 4.4 Sport Black with Black
1998 Suzuki TL1000R, power commander, ART cans, K & N, TRE
gchristofi
Post by gchristofi » Sun Nov 28, 2010 10:37 pm
I was wondering why the x5 was so bad for freezing door syndrome aswell! Is there anything that we can put around the sealing edges to stop this happening? Is petroleum jelly a good/bad idea?
blingsta
Post by blingsta » Sun Nov 28, 2010 10:45 pm
ive never had a problem with pouring warm water all around the doors seals and handle.. not hot, just luke warm, always does the trick :thumbsup:
millerman1ac
Post by millerman1ac » Sun Nov 28, 2010 10:48 pm
prob be good until you rub yer clothes against it when getting in!!
i used to put that on my mr2 t-bar roof to stop the rubber sticking over the winter...
i think what i was feeling on sat morning was more to do with inside the door, like somethin sticking! don't know how to get around that apart from building a garage lol
rbell11
Post by rbell11 » Sun Nov 28, 2010 11:01 pm
Had this last year and read a lot about it - seems a couple of problems persist.
The door handle carrier on older models can freeze and then break, and on all models the cables get moisture and subsequently freeze. The latter was my issue. Apparently good sprays of silicone lubricant or other moisture repelling spray can help. Lots of posts on american sites where members suffer this type of weather regularly.
Hope mine are okay tomorrow its baltic round here.
2004 3.0i Sport 22" wheels LPG convert
millerman1ac
Post by millerman1ac » Sun Nov 28, 2010 11:08 pm
mmm mighty cold here the night, will let youz know how it goes in the morn!!
Rusty
Post by Rusty » Sun Nov 28, 2010 11:12 pm
Try making sure the door rubbers are dry before you close the door for the last time. It's usually just the moisture on the seal that freezes.
Worth a go?
Runabout - E92 3 Series Coupe
Mole
Post by Mole » Mon Nov 29, 2010 7:55 am
yeah i'm sure its the moisture freezing so quick on the rubber seals to ! had to poor warm water all over the door this morning and it opened fine. also thought about vasaline or something similiar but as you say seems a bit messy !!!!
gmc15
Post by gmc15 » Mon Nov 29, 2010 8:17 am
I try all doors gently and thet get in the one that is free! usually one of the back ones. I then climb in the car, start engine and open the front doors from the inside. Problem then is that doors sometimes will not close :(
Whatever you do don't pull handles too hard as mechanism inside snaps easily and it's a fiddly repair :)
x6 M50d
Rick
Post by Rick » Mon Nov 29, 2010 8:26 am
[quote=""gmc15""]I try all doors gently and thet get in the one that is free! usually one of the back ones. I then climb in the car, start engine and open the front doors from the inside. Problem then is that doors sometimes will not close :(
Whatever you do don't pull handles too hard as mechanism inside snaps easily and it's a fiddly repair :)[/quote]
I have sprayed all door seals with silicon which has helped
My wife[bless her]had broken my door handle pulling to hard :x i managed to repair yesterday took 1.5 hours
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
gmc15
Post by gmc15 » Mon Nov 29, 2010 8:40 am
I broke the passenger handle last year and had to buy a new carrier. Took me hours as well :( and lost a bit of flesh in the process.
Drivers broke a few weeks later but the door was closed and could not be opened from inside or outside, so I took it to my local indy who managed to repair it :)
I now take great care when trying the door handles in cold weather. Had -11 C yesterday when I went to work at 06:00hrs in the morning :o
x6 M50d
millerman1ac
Post by millerman1ac » Mon Dec 06, 2010 8:41 pm
[quote=""Rick""][quote=""gmc15""]I try all doors gently and thet get in the one that is free! usually one of the back ones. I then climb in the car, start engine and open the front doors from the inside. Problem then is that doors sometimes will not close :(
My wife[bless her]had broken my door handle pulling to hard :x i managed to repair yesterday took 1.5 hours[/quote]
looks like the wife has done the same to mine... drivers door handle sticks out a wee bit now and wont open the door for the last 4 days now!.. have to unlock car and open from the inside :cry:
will invetigate more once/if the frost goes!!
ChewingBacca
Post by ChewingBacca » Mon Dec 06, 2010 9:16 pm
Same here with the drivers door handle, -17°C last Friday. Got it fixed under warranty today.
phiggystardust
Post by phiggystardust » Mon Dec 06, 2010 9:17 pm
fitted a new carrier last week cost £61 +vat from the local dealers , take your time removing handle can be tricky, see sanj's write up .it is as it says .100% very helpfull
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
