Fitting Gen 13 ULF
nujon
Fitting Gen 13 ULF
Post by nujon » Thu Nov 14, 2013 8:58 pm
Can anyone advise what is involved in fitting a Gen 13 ULF in place of the factory-fitted TCU-Assist (2006 X5) - is any rewiring required and can I keep the existing eject box?
Re: Fitting Gen 13 ULF
Post by X5Sport » Thu Nov 14, 2013 10:26 pm
What was the Gen 13 fitted to?  If you know the part number try entering it into Realoem and doing a part number search.  That should show you what cars it was/is fitted to.  If the E53 comes up then it may well be plug and play  :)
nujon
Post by nujon » Thu Nov 14, 2013 10:32 pm
Thanks - the Gen 13 would be a new purchase via Bimmernav USA (my existing TCU is u/s and I don't want the Assist function anyway)
Post by X5Sport » Thu Nov 14, 2013 10:39 pm
Be careful in that case as the US phone frequencies are completely different from the UK/EU ones.  Make sure it's a UK version.
Steamyrotter
Post by Steamyrotter » Thu Nov 14, 2013 10:47 pm
The Gen 13 is the ULF type and is a bluetooth connection to the phone.
Doesn't have any phone transmitting function AFAIK..
However....
I don't think its a direct replacement for a TCU!!!
I believe they have different connectors and ancilliaries (but could be wrong...)
Not impossible, just most probably a job the likes of someone like me would undertake!!!!
mennie
Post by mennie » Sat Nov 16, 2013 7:15 pm
I'm using this website:
http://www.bimmernav.com/BMW_X5_Bluetoo ... tions.html
At the moment I'm having some trouble, don't know if you will run in to the same ;)
My car was fitted with the Motorola V, SA 629 ancient GSM system.
- Going from DB 25 to the ULF 54 using the adapter harness, I'm missing the I-Bus pin in the cars harnass.(That was probably going to the stuff in the armrest instead of in the back, because navcoder did read it when it was still connected).
- The eject box wires are going through the hinge of the armrest, I don't see how I can ever fit an iPhone eject box cabling in the same way.
- Still have to search for the SES jumper, it was not behind the CD player but should be near the DB 25.
- I've attached a simple pairing button, but not tested yet because no I-Bus.
The GSM module in the back of the car had a coax antenna connection, one of the advantages of still using the eject box should be to use that antenna. But that would have to be wired to the armrest I guess.
Aug '00 X5 E53 (M54)
nujon
Post by nujon » Sat Nov 16, 2013 8:57 pm
[quote="mennie"]
My interest is adapting my installed SA633 system (TCU) to SA644 (ULF) - Bimmernav say all I have to do is swap the modules but I'm not convinced noting the two systems have different ancilliaries
mikem
Post by mikem » Sun Nov 17, 2013 8:56 am
Pretty sure I found the SES near the drivers side rear light the other week when cleaning the bulb contacts ?
mennie
Post by mennie » Sun Nov 17, 2013 4:48 pm
I've gotten the whole thing to work, with my BB Q10.
My ULF module is the oldest first generation, 84 21 6 934 552, but everything seems to work initially.
Took IBus from the CD player (for now).
Paired, transferred numbers and made a call.
Don't seem to need the SES plug, however sound quality is bad and volume is low (under construction).
Don't know about replacing anything but I do know what some of the wires are for.
db25 ULF use
car adapter pin pin
x 1
x x 3 36 KL31 Ground
x x 4 17 KL30 +
x x 5 35 KLR Ignition
x 8
x x 10 51 Mute
x x 11 32 TXD Pairing
x 12
x x 14 19 Mic -
x x 15 1 Mic +
x x 16
x x 17
x 18
x x 19 37 Speaker +
x x 20 21 Shield
x 21 33 Tel On
x 22 15 I Bus
x 23
x 24
x x 25 38 Speaker –
(first column "car" is what I found on the car harnass, second column "adapter"is what the db25 to 54 ULF adapter has wired)
