Quick oil separator question
J8NWK
Post by J8NWK » Mon Nov 11, 2013 4:55 pm
Just a quick one.
The oil breather/separator on the 3.0d, if the car has the new style all plastic separator fitted rather than the cotton filter does it still need replacing ? Surely if it's just all plastic it can't really make a difference ?
Sanj
Re: Quick oil separator question
Post by Sanj » Mon Nov 11, 2013 5:01 pm
Yeah - leave it be. Makes no difference.
J8NWK
Post by J8NWK » Mon Nov 11, 2013 5:38 pm
I thought as much.
Thanks for the reply !
max
Post by max » Tue Nov 12, 2013 9:40 pm
Sanj, would you say the same if your going to be changing air and fuel filters and access to the breather will be right there?
I'm just thinking for the sake of the cost of the part c.£30 it should be changed or is it simply a waste of money if I've already got the later vortex style breather
Post by X5Sport » Wed Nov 13, 2013 12:05 pm
The air filter requires all the same bits removed as the separator so it is a no brainer.  The separator is easier to do than the air filter.
Our E46 with the same engine had the later separator but at 55k miles I still changed it as I had one in stock.
In the piccie below are the yellow screws to lift the injector loom and the red bolts that hold the separator.  The air filter (removed) runs along the bottom of the picture.
Sanj
Post by Sanj » Wed Nov 13, 2013 12:07 pm
The part was redesigned from the original to get over the clogging issues. It was a foam type and would eventually strangle and choke...
So yes, it's right there for replacement purposes when you're doing the filters but I just don't see the point of replacing it when it can't clog up any longer. But anyone's choice...
