Rear camber thread ?
Frontman
Post by Frontman » Sun Nov 03, 2013 9:07 am
Hi I  had a search but can not seem to find a post re: correcting / adjusting rear camber. Or did I just imagine it ?
Cheers for any pointers.
My Other car's a Hilux Surf.
shadrack
Re: Rear camber thread ?
Post by shadrack » Sun Nov 03, 2013 10:26 am
there is one somewhere, there is camber adjustment and theres also so plates available to give more adjustment, think raj knows alot about this
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Frontman
Post by Frontman » Sun Nov 03, 2013 8:20 pm
Cheers for that, I'll just have to wait for his Rajness to impart his knowledge.
Raj
Post by Raj » Sun Nov 03, 2013 8:43 pm
His Rajness is here lol.
Hmmm, there was a thread on the K-Mac poly camber bushes etc. but if you're just trying to adjust the rear camber (standard) setup then there is only one point on both sides at the rear. Looking under the X from the rear the camber is adjusted at the inner rear lower H arm bush. You'll see the offset bolt/washer which when loosened then turned will increase/decrease the camber.
The upper front arm on the rear setup also works in the same way but is for the toe.
Does that help?
Frontman
Post by Frontman » Sun Nov 17, 2013 2:28 pm
Thank you for the replies folks, and Raj thanks as ever for imparting your knowledge on us mortals. I have noticed that the X5 has always had a large camber, but the rear tyres have lasted a year with below average miles. It's just started to rain so it must be time to get outside !
Raj
Post by Raj » Sun Nov 17, 2013 4:18 pm
You will find BM's especially the X run negative camber on the rear as standard. The X does seem to have an increased level of negative camber though.
X5LAW
Post by X5LAW » Tue Jan 27, 2015 3:04 pm
Would members be willing to post a pic of the x 5 from the rear so I can see what it should look like. An iphone shot from 5m behind for some rough kind of consistency would be great. I'm just not sure if mine is excessive and would love some comparison data.
Thanks in anticipation
Post by X5Sport » Tue Jan 27, 2015 4:39 pm
Any good?
Dimsum
Post by Dimsum » Tue Jan 27, 2015 6:44 pm
Ove noticed mine seems to be running less camber than quite a few I've seen about. Will try and remember to take a pic tomorrow.
X5LAW
Post by X5LAW » Tue Feb 03, 2015 12:45 pm
Thanks, I think mine is a little over that camber. I'm also suspecting the softer winter compound will show uneven wear faster than the regular rubber, right?
Seems to point towards needing attention. No worries, I'd rather it was right.
