Rear wiper is not clearing screen.
Newblade makes no difference
Rear wiper
Re: Rear wiper
You could try very gently bending the arm to make better contact with the glass, or the pressure spring may be soft.
Smeeagain
Re: Rear wiper
[quote="MAZI"]
Almost certainly the pivot arms needing cleaned (prevents the arm pressing the blade against the screen properly) - comes up on here regularly - go to Search then type in rear wiper arm, read the posts and you will find the answer you need ...... and unless your blade needed changing anyway then keep the old one as a spare as there probably wasn't anything wrong with it
Smee
Smee
- Willbof
- Dimsum
Re: Rear wiper
I ended up replacing the whole arm.... seemed easier in the end!
Sent from my GT-I9300 using Tapatalk 2
petert
Re: Rear wiper
Lubricating the pivot worked for me and only took a few seconds.
Peter T
Peter T
