Good Evening
I took my 2003 X5 to the indi menders and they have quoted £550 to supply and fit my buggered aircon compressor and clutch.
That's a lot of money for a few days of the year when we need to use aircon........I think you'll all agree.
Can any of you suggest what I should do?
Is £550 a pisstake?
Anyone know where I can source these parts at a reasonable price, after all its a 10 year old car!
Raward
E53 Expensive AirCon fault
Raward
2003 X5 pre-facelift
Re: E53 Expensive AirCon fault
The problem is that unless the system is run regularly (at least once a month) the seals dry out due to the fluid also being a lubricant and that's that. To be honest I never turn mine off. The systems can lose up to 15% gas volume per year normally so need checking every 5 years or so, more often if not used. It's called 'Climate Control' for a reason. It's not just a/c and needs using.
Citroen were well known for it a few years back, and that price is about what I would expect from an Indy, BMW will probably want over £1k.
Never anthropomorphise computers. They hate that.- shadrack
that will be right as air con compressor will be expensive and they can be a pita to fit
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
Denis O
See what someone like Quarry Motors will charge for a 2nd hand compressor and then either fit yourself or have your indy fit it.
http://www.ebay.co.uk/itm/BMW-X5-SE-D-A ... 53f491c4a8
05 Mercedes SL350
05 Mercedes SL350
