Strange sound from front of car
Chief1409
Sounds like the noise the power steering used to make on the first gen BMW Mini.... Continually cycles between high and lower pitch but only when aircon fan is on. Any ideas folks?
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'03 Renault Clio 1.2
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
Re: Strange sound from front of car
Could be the compressor cycling in and out, or the a/c fan doing the same?
R
R
Mike80
If the sound is like a humming from the interior heating water pump, very faint when radio is low. it does sound like mine and i was told this was normal when I took a BMW mechanic out for a listen.
After doing a bit of research on google it does seem to be a very common BMW problem, I'd be interested to know if any other e70 owners have this noise when the heating fan is set to one or two bars after at least 15 min of driving.
Mike
Mike
Chief1409
Got the power steering recall work done yesterday and seems to have stopped the noise. From what you lot know of the recall could it have caused the noise I described?
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
Mike80
I also have had the recall done in the last week but still hear the noise when radio is on low, will have a look under the bonnet next time it happens to see if its anything obvious
