Webasto Heater problem
Posted: Mon Oct 25, 2010 1:28 pm
by paulbryson75
Installed a T90 Control last year to run my Webasto heater - went to use it this morning - first frosty day.
Once I press the 'on' button on the keyfob I just get a series of rapid red flashes on the light - as opposed to it going 'solid' and the heater does not come on.
Wonder has anyone any ideas?
I fitted this as DIY job having bought the fob from the old forum - wondering would the lights flash like this if a wire had come loose on the loom (under the boot) - or could it be a fuse issue?
Any help appreciated.
Paul
Re: Webasto Heater problem
Posted: Mon Oct 25, 2010 2:19 pm
by squeaky2
The rapid flashing usually indicates a lack of communication with the remote receiver. MIght be worth pulling the fuses and resetting it. I think to reprogramme it you have to start pulling other fuses but i will have to try and dig out the manual for mine
Posted: Sat Oct 30, 2010 5:33 pm
by jason@bwchiptune
we have programmed the standard webasto heaters to work the same as the european cars with out the need of any extra remotes,this can be done on uk cars,the dealers say it can't be done and will sell you a kit with a remote
so to set once we have programmed this in to the car
you will just set the heater to come on at the time you want in the on board computer,
when set the red fan light will stay on about the right hand button to show it is set
Posted: Sat Oct 30, 2010 7:31 pm
by BL02WAS
awesome!!!!!! next meet im having this programmed, what is the charge please??
Posted: Sun Oct 31, 2010 12:27 am
by rconwa11
Yeah does the car need to be present for this Jason ?? What is the cost ??
Posted: Fri Nov 05, 2010 2:29 pm
by BL02WAS
bump jason!!!!!!
