Page 1 of 2
Dipped beam
Posted: Sun Dec 09, 2012 5:38 pm
by jimes256
I find it hard to believe the non xenon headlights on my facelift were deemed acceptable by bmw. My mk1 golf had better lights and that's saying something! Are the hid conversion kits any good? High beam is fine but not only does dip not project very far they are just so dim!
Dipped beam
Posted: Sun Dec 09, 2012 6:05 pm
by kkodal78
HID is the way to go ;)
Re: Dipped beam
Posted: Sun Dec 09, 2012 6:51 pm
by Raj
[quote="kkodal78"]
Agreed and tbh even the standard xenons aren't much better on the E53.
Re: Dipped beam
Posted: Sun Dec 09, 2012 7:05 pm
by jimes256
Thanks guys. Where/which ones did you get?
Dipped beam
Posted: Sun Dec 09, 2012 8:21 pm
by kkodal78
Mine had xenons but did nit like the brightness so went for the 75w kit. ;)
Re: Dipped beam
Posted: Sun Dec 09, 2012 9:20 pm
by crofter
Hi, jimsy, I have to agree, the dip on my 02  prefacelift is also terrible!! I fitted Osram Nightbreakers today so will see what they are like tomorrow. What wasn't helping was the condensation inside the unit!! I have dried it out with a hairdrier then siliconed all round the joint. As a final touch I sprayed all round the joint plus all the lamp entries with ignition sealer so fingers crossed!! Just a thought, might be worth checking yours for condensation too.
cheers crofter
Re: Dipped beam
Posted: Sun Dec 09, 2012 10:16 pm
by Raj
[quote="jimes256"]
Something like THIS will do you nicely.
Re: Dipped beam
Posted: Tue Dec 11, 2012 10:04 pm
by crofter
Sod's law, with all the muking about and cold hands working on the lights, I didn't shut the boot properly and flattened the battery, DOH!!  Got her started today, Nightbreakers a definite improvement but still not great so am waiting for quote for reflector suitable kit, will post update,
cheers crofter
Dipped beam
Posted: Tue Dec 11, 2012 10:23 pm
by kkodal78
why not go for a projector type headlight assembly first?
Re: Dipped beam
Posted: Tue Dec 11, 2012 10:52 pm
by Raj
[quote="kkodal78"]
But that's an additional cost tbh.
Re: Dipped beam
Posted: Fri Dec 14, 2012 10:51 am
by BIG DIN
Guys i already have the factory fit xenons on mine. If i wanted to change the bulbs for brighter ones can i fit new ones straight or do i need to upgrade the ballast as well?
Re: Dipped beam
Posted: Fri Dec 14, 2012 10:56 am
Ideally you should also upgrade the ballast at the same time.  From recent tests you can run a bulb from a higher powered ballast (bulb longevity still unknown) but probably not the other way around.
If the OEM ballasts can cope with a 55W lamp then you could be OK though.  There was a discussion about the 35W/55W ballast actually being the same beast and really being a 55W 'under the hood'.
Re: Dipped beam
Posted: Fri Dec 14, 2012 1:40 pm
by BIG DIN
So at the moment i probably got 35w bulbs???
Re: Dipped beam
Posted: Fri Dec 14, 2012 2:56 pm
by Raj
[quote="BIG DIN"]
After many discussions with xenons it is the ballast supplying the different wattages to the bulbs so I'd say upgrade the ballasts first for 55w versions as I'm planning on doing.
Re: Dipped beam
Posted: Sat Dec 15, 2012 10:07 am
[quote="BIG DIN"]
OEM Default is for 35W, yes.
