eurotunnel
mpgrant70
eurotunnel
Hi have any of you forum members taken there e70 on the eurotunnel can you use the normal height or did you have to go to oversize at 1.85mtrs ? I am about to book but not sure which is best ?
- Black X5
eurotunnel
It is possible to use the regular sized ones, but it is much easier if you use the larger ones for coaches/ minibuses etc.
We used the regular one on the way out. It was tight in the E70, but my brother who at the time had an ABT Q7 ended up 'kerbing' his newly refurbished wheels!
We used the larger carriages on the way back and it was much better. The larger carriages are taller and more importantly wider.
E70 3.0D SE, Black with Black - Gone but not forgotten! >:D
- 535dboy
- Lifer
Re: eurotunnel
You can go in the normal carriage but try and get in the coach one. Generally quite easy to do, 98% of the time we bring the track cars back in that one - only problem is the kids love them!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
- pvr
- Lifer
Re: eurotunnel
I have taken the E70 a few times in the tunnel. The height is no problem, I find the width more of an issue but if you don't have a roof rack and the train is busy, they might still put you at the low side (I have booked high side before and they still put me in the lower decks).
squeaky2
Re: eurotunnel
as everyone else has said it is possible but is quite a squeeze.....height is no problem though.
Only ever gone through on the high carriages in the van so dont know how easy it is to book but i assume that you just say that youre vehicle is overheight.
Tend to see things like Disco's and RR's on the high carriage side so im assuming there are no problems
stevee
Re: eurotunnel
Agreed. With 20" wheels , there's only a couple of inches to spare .. but fortunately the curbs are low and so far (touch wood) no wheel damage .. though lots of squealing from the tires. Height not a problem.
S
S
X5 E70 (2011)
- 535dboy
- Lifer
Re: eurotunnel
[quote="stevee"]
S
But they are metal curbs and that worries me!
S
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
- Black X5
Re: eurotunnel
A few pics of the X in the smaller carriage.
Just incase you need to get to the boot!
Oh and here's a pic of the AS7's kerbed wheel :'( (there was one more on the other side!)
graemeX5
Re: eurotunnel
Got to say the pic of the kerbed wheels makes me cry :cry1:
I know understand why you definitely want the larger carriage for your X
Riggie
Re: eurotunnel
I assume hat the E53 will be a bit better, as it's slightly narrower? I'm booked for a crossing in December.
graemeX5
Re: eurotunnel
According to Wikipedia width of e53 is Width 73.7 in (1,872 mm)
The e70 has 2 widths not sure why
Width 1,933 mm (76.1 in)
M: 1,994 mm (78.5 in)
- pvr
- Lifer
Re: eurotunnel
Never had à problem with the e53. Only e70 became scary.
Re: eurotunnel
My E53 was fine going through a standard garage (2 metres wide/high) but the E71 is too wide.....as Bonnie says, it's got a fat arse. At least I think that's what she was referring to..... O:-)
Riggie
Re: eurotunnel
[quote="graemeX5"]
An extra 2 inches makes all the difference !
- mogsyman
eurotunnel
[quote="pvr"]
Likewise, the E70 is tight and you have to watch the wheels but it'll fit either way.
If you don't book the coach wagon when you book Eurotunnel they may not let you on it during busy periods as technically it fits in either the ground or top deck.
Sent from my iPad using Tapatalk HD
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
