Garage Clearout
Posted: Thu May 10, 2012 11:47 pm
A few bits and pieces I found sorting out the garage today.
1) Pair of replacement LED angel eye bulbs. Ideal upgrade to replace the standard yellow halo's. Will fit Facelift E53's and E60's. Tested but never properly used - SOLD
2) Set of all black wheel badges. Nice little mod (can source the bonnet and boot badges if required at extra cost). Will fit E53's, E70's, E71's, etc. Used for about 2 weeks - £35 delivered.
3) Gear knob with Titan trim piece. Slight mark (as can be seen). Replaced with AC Schnitzer item - £20 delivered.
4) Eibach Hubcentric 20mm Type 7 spacers and bolts. These (as can be seen in the pics) are bolted to the hub and the wheel is bolted to the spacer. More secure mounting and less stress on the bolts, etc. The different bolts required are all included (example of each shown) and were used for about 2 weeks. Bought from CA Automotive for £140. Will fit E53 (rear of E71 also) - £100 delivered.
5) Belkin N Wireless Router. Excellent router. Missing the USB adapter but not really an issue as nearly all laptops/PC's are wireless enabled already. £25 delivered.
