HELP!
John
HELP!
Post by John » Mon Mar 19, 2012 7:40 pm
guys,
just driving home and noticed my indicators had stopped working, they light up but dont flash - no problem i thought it'll be the flasher unit.
So i gets home, turns off ignition but the radio stays on, the brake lights have stayed on and theres nothing when i go to start her up, the key just turns as normal but the engine dosnt crank over,
the central locking dosnt work either, altho the boot release on the key fob works????
This has all just happened in the space of 20 mins, was on my way back from Bristol airport after working abroad, thank god it didnt happen there!
any ideas? or at least wheres the battery so i can disconnect it til tomorrow and get it towed to the nearest Beemer dealer
02 X5 3.0D Sport
graemeX5
Re: HELP!
Post by graemeX5 » Mon Mar 19, 2012 7:52 pm
Hi I'm not sure but if the engine doesn't turn over it could be the battery. a quick test would be if you put headlights on full do they dim after a minute or so then the battery is low on power.
It may be worth charging it overnight unless you have a battery tester to hand to check it which most garages will have and they can confirm the condition of the battery.
Hope that helps
Re: HELP!
Post by X5Sport » Mon Mar 19, 2012 7:53 pm
Battery is in the boot under the spare wheel!! It's almost at the back of the car in a plastic bucket. BMW put it there as part of their plan to have a 50:50 weight split front to rear.
You'll need to remove the wheel and then release the bolts and nuts holding the support frame for the air pump (in the domed device) so you can lift it forwards. Battery terminals can then be got at.
No idea what might have gone haywire though. Sometimes disconnecting the battery for an hour will reset everything. A bad/dying battery can cause all kinds of fun with these vehicles. If you've left the car for any length of time I would defo suspect the battery and/or alternator - but battery first. As suggested above, give it a charge and see what happens. It the battery is more than about 5 years old then probably approaching end of life.
John
Re: HELP!
Post by John » Mon Mar 19, 2012 8:48 pm
thanks for the replies lads, the car was only sitting since last thursday, so not long, everything electrical was working fine and strong before this, i think the batterys is around 2 years old, ive disconnected it for now, the boot is now locked and i cant get it open, its been a very long day(started out in casablanca 13 hrs ago!) so im leaving til the morning before i start messing about trying to open the boot, thanks again for now guys
02 X5 3.0D Sport
pvr
Re: HELP!
Post by pvr » Mon Mar 19, 2012 8:55 pm
Just don't drive like they do in Casablanca ... :D
John
Re: HELP!
Post by John » Mon Mar 19, 2012 9:10 pm
you aint joking there pvr
02 X5 3.0D Sport
pvr
Re: HELP!
Post by pvr » Mon Mar 19, 2012 9:18 pm
I know .... never been in a taxi there without having some sort of accident. Hyatt nice though :)
John
Re: HELP!
Post by John » Mon Mar 19, 2012 10:02 pm
again, your not joking, spent the last 4 nights in the hyatt, very nice indeed!!
02 X5 3.0D Sport
John
Re: HELP!
Post by John » Tue Mar 20, 2012 10:31 am
quick update lads,
i reconnected the battery this morning, everything is ok and working again,
so i took it to the nearest indy dealer in swansea, who said somehow it had last a signal but disconnecting/reconnecting the battery would have fixed it
so reasonably happy, but now gonna carry tools required to disconnect battery in the boot
02 X5 3.0D Sport
pvr
Re: HELP!
Post by pvr » Tue Mar 20, 2012 10:40 am
Good result.
What battery do you have in the car by the way?
John
Re: HELP!
Post by John » Tue Mar 20, 2012 12:15 pm
its a bosch battery
02 X5 3.0D Sport
Re: HELP!
Post by X5Sport » Tue Mar 20, 2012 12:26 pm
These cars are known for throwing all sorts of erroneous and confusing messages and actions if the battery goes bad. At two years old yours should be OK. And as you have found, disconnecting it for 30mins to an hour or so will reset things. It sounds like you need to charge it from under the bonnet (jumper points) and then see what voltages it shows 4 hours after charging (approx 12.6) as well as what the voltage is with a charged battery and the engine running. The latter should be 14.4 to 14.6V.
