Rear Wiper doesn't clear screen
Posted: Thu Sep 16, 2010 7:14 pm
by nickt68
Would be grateful for any advice - my rear wiper only wipes part of the rear screen and has been getting progessively worse over the last year. It seems as if the wiper blade is not making contact with the screen through most of its arc. Found a post on another site detailing the same problem and said that it was caused by muck etc in the "pivot point" which could be cleaned out. Not sure what the pivot point is though - maybe the hinge on the arm or the spindle going through to the motor?
If anyone has had a similar problem and fixed it would appreciate some advice please - I've already tried a new blade but no good!
Re: Rear Wiper doesn't clear screen
Posted: Thu Sep 16, 2010 8:36 pm
by philip600
Hi, Mine was like this as well.
Try cleaning the bit that hinges to allow the blade to be swung away from the screen & spray a little WD40 on it. Also make sure the spring inside the wiper bade arm is clean & not corroded.
I then had to carefully bend the blade at the end to ensure it stayed in contact with the screen over it's full sweep.
It took a bit of fiddling but It's been no problem since.
Hope this helps ?
Phil.
Posted: Thu Sep 16, 2010 8:51 pm
by Sanj
I have to do this. After lifting it from the rear screen when washing I've found it is not touching in the centre...
I'm gona have to try that. Thanks philip600!
Posted: Fri Sep 17, 2010 3:52 am
by Turks
Yeah, over time the wiper cage can seize up due to crud collecting in the pivot joints, same for the spring on the wiper arm itself. I took the wiper off the arm and cleaned it in a bucket of water, dried it and then worked in some WD40 by wiggling the joints back and forth. I then just used a drop of 3 in 1 on the joints to keep it in good working order. I removed the Arm from the Spindle and cleaned up the spring with a wire brush and then wire wool and then covered in Vaseline. Put it all back together and works a treat.
Turks.
Posted: Fri Sep 17, 2010 9:39 am
by nickt68
Thanks Phil and Turks, will have a go over the weekend and hopefully will be able to see out of the back window again by Monday
