Just when I was gonna treat it...
Posted: Thu Sep 09, 2010 9:01 pm
by MaximumJed
Booked my 4.6 in with jason today for a little work to hopefully sort out all the little issues I have been having, thought to myself, "That'll get everything sorted, no worries for a bit".
Get back to the car park and there is a little puddle of oil under the front left! Gutted isn't enough of a word
Any ideas of common issues? Maybe rocker cover or vanos?
Re: Just when I was gonna treat it...
Posted: Thu Sep 09, 2010 11:04 pm
by macky
Could be many things tbh but check power steer fluid level at the reservoir as I have seen the hoses leak quite a few times.
If the oils dirty black its engine oil.
Posted: Fri Sep 10, 2010 10:44 am
by MaximumJed
Definitely engine oil rather than power steering fluid.
Posted: Fri Sep 10, 2010 7:22 pm
by pvr
Thought most of that would have been caught by the under tray though?
Posted: Fri Sep 10, 2010 11:29 pm
by thedweeb
[quote=""pvr""]Thought most of that would have been caught by the under tray though?[/quote]
I thought that but I suppose if it was leaking for long enough it would find its way out.
Posted: Tue Sep 14, 2010 10:24 pm
by MaximumJed
Turns out that it is the cam cover gaskets, apparently a laborious process as I have been quoted £800 and a whole day to fix it
Posted: Wed Sep 15, 2010 3:49 am
by Turks
That is a hell of alot of oil to be leaking from the cam covers to create a puddle on the floor
Have you noticed it consuming a lot of oil before you noticed the puddle?
Turks.
Posted: Wed Sep 15, 2010 8:02 am
by MaximumJed
About a litre per 1,000 miles I think. Maybe a bit more. I assume it had been leaking for a while and created a pool in the undertray which eventually leaked over.
I had an Inspection II done over the last couple of days and the cam gaskets was the verdict, no traces anywhere else on the block apparently.
Posted: Wed Sep 15, 2010 12:13 pm
by IanP
[quote=""MaximumJed""]Turns out that it is the cam cover gaskets, apparently a laborious process as I have been quoted £800 and a whole day to fix it
Considering the amount of stuff that has to be removed to get to the cam covers, thats not too bad
