Well tomorrow it goes to indy for pressure test with view to water pump needing replacement, thermostat change as cost effective preventative work & resultant coolant change. Considered doing this then saw the d.i.y. guide & decided in absence of special tools to pay someone competent to do the work. In any case it would need a pressure test before & after & I cant do that.
As well as this the aux pusher fan is dead. I was going to do this myself d.i.y. but faced with the joy of having to pay for the aforementioned as above I felt bitter getting all that sorted only to not be able to use the a/c in hot weather &/or static/slow traffic also aware a bad pusher fan can cause current drain & I have this too. Also make sense to get a/c re-gassed as I wouldn't be happy paying out for al above only to have poor a/c. I don't think mine has been checked re-done since new & car is approaching 10 years old with over 100k on clock.
Fitting a/c pusher fans isn't rocket science though a PITA as it's a case of loosening whole front bumper. The fan alone is listing at £380 so if paying for all the above work plus the new fan I would feel bitter if I had to crawl under the car cursing. If I had been able to source a used one for up to maybe £150 then I would have fitted it myself. These can fail at 65k but sadly none available - One cheeky breaker offered me one for £275 from a car with 98k on odometer ! .......I declined & told him he was taking the mickey. In trying to source a decent used pusher fan I tried all usual routes with many hours spent over many days making multi calls, sending emails & using online parts finder searches but fruits of my labour yielded nothing
The above booked in for tomorrow, then before long it will be new discs & pads.......I will, however, do those myself. Z3 still needs a new sump but currently can't find a sensibly price salvage one of those either
