Stability control fuse
Lincssailer
Post by Lincssailer » Sat May 21, 2022 1:57 pm
Hi been having a problem with aux socket not working so looked ar the fuses in the rear, now getting xdrive stability not working so presume i have disturbed the fuse for it but cannot find which one, anybody got a clue please
Post by X5Sport » Sat May 21, 2022 3:26 pm
Any clue on the fuse card? 15, 19, 40, 46 and 123 all seem to be related. Possibly 125 as well (it’s also related to 123). 100+ numbers are in the rear. Wiring diagram says 19, 40, 46 are key to the module supply.
This might help…https://youtu.be/aQDDCG7cVp4
Post by Leslie » Sat May 21, 2022 4:05 pm
I'd think it will sort itself out after a short drive assuming you put the fuse back in the right place :thumbsup:
Lincssailer
Post by Lincssailer » Sun May 22, 2022 9:10 am
Thanks yes its sorted but now when i switch on i get a sos warning with a telephone with a line through it, presume this must be a fuse as well
Post by X5Sport » Sun May 22, 2022 10:18 am
Fuses 5, 19, 114, 117. Power for the SOS function comes from the roof functions control module. Depends upon your car spec but there might be a gap where there shouldn’t be, or a blown fuse.
It might also just need to reconnect itself to the BMW Connected Drive servers.
Lincssailer
Post by Lincssailer » Sun May 22, 2022 7:44 pm
Thanks will check the fuses in the morning
Lincssailer
Post by Lincssailer » Mon May 23, 2022 7:43 pm
Ok thanks for the info so sorted everything else but now no radio sound, lists stations but silence, its got to be something in the rear fuse box and the small fuses
Post by X5Sport » Mon May 23, 2022 8:17 pm
You’re not having a good time are you…. :o
This might help: https://fusecheck.com/bmw/bmw-x5-e70-20 ... se-diagram
Fuse 103 would be a good start. I’ve checked a wiring diagram and the amp is on that fuse.
A lesson I learned the hard way was to take a photo of the fuse boxes before touching anything. Life was easy when cars had maybe a dozen fuses but today they’re a nightmare. Modern cars are a computer on wheels!
Lincssailer
Post by Lincssailer » Tue May 24, 2022 7:56 am
Thanks, no made a total*****yes thanks for the photo tip will use that in future if i dare ever do anything else
Lincssailer
Post by Lincssailer » Wed May 25, 2022 4:57 pm
So still get the sos sign from when i start moving for a few hundred yards then it goes out, no sound on radio, cd, telephone etc, i drive works fine checked the rear board fuses and cannot find anything, its driving me mad
Post by sapphireblack » Wed May 25, 2022 5:44 pm
Think it's time to get your wallet raped. Stealer or indy who can read the fault codes.
Post by X5Sport » Wed May 25, 2022 8:10 pm
I think the amp should be in the same place as mine - behind the left cubby removable cover in the boot. It might have it’s own fuse (some versions did) on the amp itself, and that might be blown.
Be careful with the cables as some of them are fibre-optic feeds to the main iDrive computer (typical BMW OTT but … )
If there isn’t one then sadly it’s letting an expert with tools have a look after a code readout as above.
Lincssailer
Post by Lincssailer » Wed May 25, 2022 10:12 pm
Thanks will have a look
Lincssailer
Post by Lincssailer » Tue Jun 07, 2022 7:16 pm
Finally swapped a fuse and all working although i still need to get the av in the centre consul working
