relentless Alarm going off... ??
Posted: Sun Jul 11, 2021 8:45 pm
by X5-D-Sport
Good evening Ladies,
My E5 has recently taken to firing the alarm time after time.
I have looked around inside for bugs flying about or a rogue spider, but none of those.
It has become such a nuisance that I usually have to leave the vehicle unlocked.
I have chased the usual things like....
it has a recently new battery & holding good voltage, all door sensors work & trigger the interior light properly when opened, as does the tailgate, & I have given the bonnet sensor some abuse to see if it is that... & will disconnect it & see it that stops the issue.
Any one know of any other spurious reasons the alarm will trigger... ?
regards to all
Grant B
Posted: Sun Jul 11, 2021 9:30 pm
Previous reported incidents usually finger the bonnet sensor.
Posted: Mon Jul 12, 2021 6:35 am
by Alan Gunn
Mine went the same i just unplugged the bonnet sensor and no more fals triggers.
Posted: Mon Jul 12, 2021 7:07 am
by Greydog
Any other symptoms that may not seem related? radio swapping stations, indicator sounder silent, when mine started throwing the odd wobbler it turned out to be the LCM starting to fail. First sign was running a Fault code read and no communication with the LCM which in turn prevents comm's with several units
Posted: Mon Jul 12, 2021 8:09 am
by X5-D-Sport
UPDATE...
unplugged the bonnet sensor switch....
No more false alarms...
Thank you people, much appreciated.
Posted: Tue Jul 13, 2021 6:04 am
by Alan Gunn
Strang how that sensor fails i think it has failed on every car i have had.
I do tend to keep my cars a few years.
Posted: Tue Jul 13, 2021 6:27 am
by sapphireblack
This brings back memories, had the same issue on an E53.
Posted: Tue Jul 13, 2021 8:14 am
by Leslie
Alan Gunn wrote: Tue Jul 13, 2021 6:04 am
It's maybe because you actually lift the bonnet unlike 99% of drivers these days lol
Posted: Tue Jul 13, 2021 11:41 am
.........what? That big metal panel in front of me opens?
Posted: Tue Jul 13, 2021 12:37 pm
by X5-D-Sport
i pulled the sensor on Sunday evening & no false alarms since -
I prized it open, & pinned it out.... the connections were spotless, but the internals were plastic on plastic moving parts & were partially jammed in place & after i had it on the bench for a while, I heard it click... hence triggering the alarm...
Posted: Tue Jul 13, 2021 3:37 pm
by Leslie
X5Sport wrote: Tue Jul 13, 2021 11:41 am
Yes the front "boot* opens but you can't put any groceries in there as it's too hot
Posted: Wed Jul 14, 2021 7:31 am
by Greydog
Thought it was a Dealer access only
Posted: Mon Jul 19, 2021 10:47 pm
by X5-D-Sport
well people... removing the bonnet/hood sensor switch definitely solved the false alarm triggers.
Many thanks for the input.
Have a great week
Grant B
