Squeek on rear
Lincssailer
Squeek on rear
When i reverse slowly my x5 has started a squeeking from the rear shen i go over a bump, any ideas before i start replacing?
Re: Squeek on rear
It could just be a dragging disc pad. After that you’re into checking every rotating or moving part (shafts, bearings, bushes etc).
Lincssailer
Re: Squeek on rear
Sounds rubbery like a bush but why only in reverse?
- henrym3
Re: Squeek on rear
Had a similar squeek once and it was the top mount on the rear shock. When the rubber cover was removed the bush was clearly split 50% of the way round. Worth looking at.
Lincssailer
Re: Squeek on rear
Thanks will do
