E53 3.0d gearbox oil change
Roryb1985
Post by Roryb1985 » Thu Mar 18, 2021 5:17 am
Morning all, I am wanting to do gearbox oil change on my x5 with 180k on it but I went to check the clutch’s on diagnostic and e clutch is showing 750 which is at it max. The car has no running issues so do you thing it will be safe to change or just leave it
Re: E53 3.0d gearbox oil change
Post by Alan Gunn » Thu Mar 18, 2021 7:41 am
Oil and filter was changed on mine at 164k and still silky smooth now and that was 2 or 3 years ago.
Post by Leslie » Fri Mar 19, 2021 12:10 am
I'd be inclined to leave it at this stage other than top it up if low on oil. It's a tricky call.
Post by X5Sport » Fri Mar 19, 2021 7:48 am
If a sample of the oil is dirty or smells ‘burnt’ (both of which indicate wear and clutch slip already happening) then changing it could flush all of the dirt out of the system and could result in a rebuild as the clutches then slip. You might however have no issues after a change. As above it’s a hard call.
Post by Alan Gunn » Sat Mar 20, 2021 6:42 am
From memory the people that had problems after changing the oil and filter had done it because they where starting to have problems with the auto box.
As said i had no problems with mine and thought it was smooth but after the oil change it was silky smooth didn't think i would have felt any difference but i did.
Like others say it's your call.
Post by Themoog2 » Sat Mar 20, 2021 8:37 am
Doing the tranny service is defo the way to go. Do it twice. First time with new filter. Second time a week or so later just drain and refill. New fluid is better than old fluid. Debris causing problems after a service is nonsense in my opinion. If that was the case then nothing would be serviceable.
I did mine at 140k no probs. You don’t need any special tools to measure trans temp - just put your hand on the sump when it’s running and if it’s hot then that’s the time to check the level.
Only last week I was talking with a zf transmission expert and he said they are really good units. It’s the lack of service that ruins them. I mentioned the original fluid for the trans ( can’t remember what it’s called) as I used Comma multi vehicle plus fluid and he said that original fluid viscosity is too thin for higher mileage transmissions. Who knew.
Post by X5Sport » Sat Mar 20, 2021 12:32 pm
Lifeguard is the ZF fluid.
Post by Themoog2 » Sun Mar 21, 2021 4:07 pm
I knew that. I just forgot..
