Any recommendations?
Smeeagain
Post by Smeeagain » Fri Aug 23, 2019 4:46 pm
Any recommedantions/links please for front and back dashcam system?
Smee
Re: Any recommendations?
Post by StuBeeDoo » Fri Aug 23, 2019 4:57 pm
Smeeagain wrote: Fri Aug 23, 2019 4:46 pmAny recommedantions/links please for front and back dashcam system?
By "front and back" do you men the dual lens type? Or are you after 2 separate units - one front, one rear?
sleepyfolk
Post by sleepyfolk » Fri Aug 23, 2019 6:37 pm
Haven’t done a front one but I put one of these number plate rear ones in, good picture and I preferred it to one looking out the back window or those off centre number plate light things
https://www.reversingcamerasuk.com/ccd- ... amera.html
Post by X5Sport » Fri Aug 23, 2019 8:58 pm
I use a Nextbase 512GW for the front and have the rear one to fit in due course, and when I find how to feed the wire through the F46 rear to front. It plugs into the front unit but drops the recording down from 1440 lines to 1080.
I think the front unit was about £130 on a deal and the rear about £50. You can get these things far cheaper but is the video from those good enough when you really need it? Just asking, as I believe the recording data rate is very low due to image compression and you lose detail.
Smeeagain
Post by Smeeagain » Sat Aug 24, 2019 12:16 pm
Yes for clarification I meant front and rear. Not sure what a dual lens one is?
Smee
Post by StuBeeDoo » Sat Aug 24, 2019 6:18 pm
I've got a NextBase (412GW, IIRC) up front. I had a cheap'n'cheerful unbranded (well, not in any recognisable language) one in the E46 which I keep meaning to attempt to fit on the tailgate of the F25.
Post by henrym3 » Mon Aug 26, 2019 3:38 pm
I have a cheap front and back, front is wired up to Dynavin, shows a good picture which I never really look at, took the sd card out to look at on computer and it’s an even better picture which would clearly show people/number plates which is what you want in a dispute. Rear is WiFi connects to phone but again never looked at other than to check it works. Just let it loop record. Can’t remember costs but definitely under £20 each. Front has been working fine for over 3 years.
