Anybody know anything about this code
P1E25 speed sensor monitoring shaft sensor
So is it cam or crank sensor related.... or something else. And is it meaningful or just one of those that pop up when battery dies.
Combined with
P1195 rail pressure control valve
Vehicle cranks but doesn't start. Rail pressure only hitting 60 for desired 300 ish on crank
Also had a second error that's disappeared, something like pressure on crank low.
Now it points to fuelling fault. But I know before I took it on, the head was replaced. It drove afterwards but after a few loops cut out. Dash saying fuel syst. Error.
So either completely bad luck and it is fuelling related or something has gone wrong on putting it back together.... hence why I'm asking about the above code. BUT if it was linked to the head, surely pressure would still build up, just the ecu wouldn't fire and flag a sync related code..
Also, did bmw include a way of checking timing without significant dismantling?
x5 faults
Re: x5 faults
If it's cam sensor it should still start but take a few goes ,crank it won't start generally . If you can read you own codes unplug cam sensor and see if code is the same or a new code appears.
