BMW E53 X5 new discs front and rear
sid10
Post by sid10 » Mon Jul 01, 2019 2:50 pm
Bought these for the E53 front and rear discs from a main dealer will post oem part numbers later £200 for all 4 .
shy7g
Re: BMW E53 X5 new discs front and rear
Post by shy7g » Fri Aug 23, 2019 12:56 pm
sid10 wrote: Mon Jul 01, 2019 2:50 pm Bought these for the E53 front and rear discs from a main dealer will post oem part numbers later £200 for all 4 .
Hi are the disc still available?
Will the disc's fiit all variants of the E53 range, as I have the 4.6iS model?
Rich
Post by X5Sport » Fri Aug 23, 2019 1:26 pm
If the fronts are 332mmx30mm then no, you need 356x36 (used on the 4.6/4.8 V8s). 4.4 and 3.0 models use smaller front discs.
Your rears are 324x20mm (common to all V8 versions). 3.0d uses 324x12mm
