Radiator Top Hose Question
Mikee
Post by Mikee » Wed Mar 30, 2011 7:07 pm
Hi :D
I've got a large split in the top hose of the radiator. See part 1 from real oem:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
Is there any way of just replacing the main (fattest) section of pipe or do I need to replace the lot? It's also not just held on by jubilee clips like I was hoping! Has anyone replaced this part and is it easy enough?
2003 Titanium Silver X5 4.6is
1998 Titanium Silver M3 Evo SMG Convertible
IanP
Re: Radiator Top Hose Question
Post by IanP » Wed Mar 30, 2011 7:43 pm
I would replace the whole pipe, its easy to change if a bit fiddly trying to release the snap connectors
pvw10
Post by pvw10 » Wed Mar 30, 2011 9:26 pm
I replaced mine, easy enough and about £45.00 from memory.
3.0d Sport. Xenons,Tv/sat,Blinds,DVD Headrests,sidesteps,mudflaps,DSP,Walnut trim,softer leather,heated seats,remap,automatic,Oval exhaust upgrade, death ray and rockets.
Previous car; E46 M3 Convertible SMG.
Mikee
Post by Mikee » Thu Mar 31, 2011 1:25 pm
I've got the part and im going to have a go at replacing it myself. Any tips on how to get the old one off??
Powercat
Post by Powercat » Thu Mar 31, 2011 2:29 pm
I use an angle grinder to do this kind of job and then replac with normal jubilee clips,
this method works very well for me
02 x5 3.0d auto cat D
Mikee
Post by Mikee » Sat Apr 02, 2011 6:34 am
All sorted!
Was a bit fiddly and ended up with grazed knuckles but the X is back on the road.
Part was £64.01 from BMW...
For future reference i found it easier to unclip and remove the Air flow meter housing and air box to get better access to the Top hose. Strange thing happened when I first started the car up tho as the temp. gauge rose to the normal level for about 2 seconds and then went off the scale! Disconnected the battery for ten minutes and the problem has gone.... just incase any one has the same problem. :thumbsup:
