3.0sd rumble from the front
b21playa
Post by b21playa » Mon Sep 10, 2018 6:28 pm
Hi all
Getting some rumbling from the front at speeds over 30mph and increases with speed.
Has anyone ever experienced this and suggest anything!
Many thanks in advance
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
gmc15
Re: 3.0sd rumble from the front
Post by gmc15 » Mon Sep 10, 2018 6:34 pm
Is it worse if you turn the wheel slightly to the left or right? If it is it could be a wheel bearing.
x6 M50d
Groken
Post by Groken » Mon Sep 10, 2018 6:55 pm
If it's getting louder with speed and sounds like jet engine it will be wheel bearing.
b21playa
Post by b21playa » Mon Sep 10, 2018 6:56 pm
[quote="gmc15"]
Not that I remember. Will have to try again when I’m driving it next
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
b21playa
Post by b21playa » Mon Sep 10, 2018 7:02 pm
[quote="Groken"]
How to identify which one or be 100% sure?
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
gmc15
Post by gmc15 » Mon Sep 10, 2018 7:20 pm
If it gets louder when you turn to the left it will probably be the drivers side bearing, louder if you turn to the right will be the passenger one.
x6 M50d
Groken
Post by Groken » Mon Sep 10, 2018 7:51 pm
[quote="b21playa"]
[quote="Groken"]
Does it matter? It's not something you can fix yourself and garage should be able to identify it easy enough, but if you want to check for your self, best way is to put it neutral and raise and spin each wheel by hand. One that's gone should be obvious by different noise, failing that holding on to top of the strut will transmit excessive vibrations.
b21playa
Post by b21playa » Mon Sep 10, 2018 8:09 pm
[quote="Groken"]
[quote="b21playa"]
[quote="Groken"]
It does matter as I was hoping to change it out myself
Many thanks
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
b21playa
Post by b21playa » Tue Sep 11, 2018 10:31 am
[quote="gmc15"]
I missed your reply, many thanks for that
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
