Brakes
Silverfox58
Brakes
Post by Silverfox58 » Fri May 11, 2018 7:11 pm
Hi all
Any thoughts on this,
my brake peddle go's  hard when trying to brake but not all the time,
X5 30d
Re: Brakes
Post by henrym3 » Fri May 11, 2018 10:35 pm
check the vacuum pipe from brake servo to inlet manifold for breaks/perished and is fitted with a one way valve which may be faulty
Re: Brakes
Post by X5Sport » Sat May 12, 2018 12:50 pm
Also worth gently touching each wheel hub in case it is a sticky caliper.  If it is then one wheel will be warmer than the rest.  This is the symptom on my X6 - solid pedal sometimes and front right wheel warmer than the rest.  You might also get steering vibration, but not always.
New (remanufactured via Pagid) caliper here, just waiting time and weather to do it.  I’ll probably replace front discs and pads at the same time.
Silverfox58
Re: Brakes
Post by Silverfox58 » Sat May 12, 2018 1:46 pm
Ok thanks for the heads up and will check all and report back
X5 30d
Silverfox58
Re: Brakes
Post by Silverfox58 » Wed Jun 13, 2018 5:44 pm
Hi well I've tried touching the calipers there not hot ,I can't see anything on the brake pipe anything else to look at ,
Your help is needed again please  :) :)
X5 30d
Re: Brakes
Post by henrym3 » Wed Jun 13, 2018 8:23 pm
If you have done what has already been suggested then you might try replacing the rubber pipes between servo and inlet, they could be collapsing on the inside
Silverfox58
Re: Brakes
Post by Silverfox58 » Wed Jun 13, 2018 8:32 pm
Will have to take them off and have a good look
X5 30d
Silverfox58
Re: Brakes
Post by Silverfox58 » Thu Jun 14, 2018 6:40 pm
So had the vacuum pipe of today looks ok, run engine and I have air coming out, >:(
So I don't know now what else it can be,
X5 30d
Silverfox58
Re: Brakes help please
Post by Silverfox58 » Thu Jun 28, 2018 3:10 pm
Hi just come back from a run on the motor way and scared the life out of me, I have to put two feet on the brake peddle to stop,
And when I say stop I meet it takes a long way to stop, so got the car back ,up in the air got my wife to put her foot on the brakes
All the wheels are solid but the pedal is hard,
Please  please  can anyone put any light on this
I forgot to say put  carly on and it comes up with codes 004501 and 005f1e
X5 30d
Re: Brakes
Post by X5Sport » Thu Jun 28, 2018 5:45 pm
Loss of vacuum?  If the hoses are leaking you will have no servo.
Silverfox58
Re: Brakes
Post by Silverfox58 » Thu Jun 28, 2018 6:05 pm
Hi x5 if I take out the hose with engine  running and put my finger over the end , there is pressure there , can I buy the new hose from bmw
X5 30d
Re: Brakes
Post by Alan Gunn » Thu Jun 28, 2018 6:20 pm
If you put your finger over the end of the pipe does it suck a lot (with engine running).
If it does then it is a faulty servo they can get water in them and rust then kills them.
Silverfox58
Re: Brakes
Post by Silverfox58 » Thu Jun 28, 2018 6:22 pm
Humm thanks  for the reply Allen  but I'm sure it's blowing???
X5 30d
Re: Brakes
Post by X5Sport » Thu Jun 28, 2018 7:01 pm
The hose connecting the servo to the engine in the attached diagram...
http://www.realoem.com/bmw/enUS/showpar ... Id=11_3472
.....should be under vacuum with the engine running.  The vacuum pump is front left of the engine (or was on mine).
Silverfox58
Re: Brakes
Post by Silverfox58 » Thu Jun 28, 2018 7:05 pm
Thanks  x5 now I know the word vacuum means suck but I'm sure my one is blowing, is this right? Or am I wrong and if it ts this would point to the pump
X5 30d
