Hi all,
Is it ok to run a non-staggered winter setup with all corners being 284/40/R20? (Next winter of course!) Current summer setup is staggered.
Cheers,
Doug
Non-Staggered Winter Setup 285/40/20
Dogzyboy
- Rassi
Re: Non-Staggered Winter Setup 285/40/20
Should be perfectly fine, the problem is always different diametre front and rear which messes up the transfer box, which a non-staggered set avoids.
Only thing is that the staggered set up uses different off-set and width front and rear wheels, so don’t know if you are going to use existing wheels, or a specific set of wheels that has the same width but different off-set?
‘17 Alfa Romeo Giulia Quadrifoglio
ex '15 BMW X5 M50D
ex'14 BMW M5
ex '08 BMW Z4 Coupe
ex '14 Audi A6 Avant 3.0 BiTDI
ex '11 BMW M3 DCT
ex '11 BMW X3 30D
ex '07 BMW M5
ex '08 BMW X3 35D
ex '02 BMW M5
ex '98 Mercedes C43 T AMG
ex '99 BMW M Coupe
ex '93 Alfa Romeo 164 24V
ex '15 BMW X5 M50D
ex'14 BMW M5
ex '08 BMW Z4 Coupe
ex '11 BMW M3 DCT
ex '11 BMW X3 30D
ex '07 BMW M5
ex '08 BMW X3 35D
ex '02 BMW M5
ex '99 BMW M Coupe
Check on Realoem for winter options, but the standard BMW winter options on other X models are non-staggered.
You should be fine as a result.
Dogzyboy
Thanks guys.
Wheel sizes are as follows:
Fronts
Width - 10J
Offset – IS40
Part Number - 36112284654
Rears
Width – 10.5J
Offset - IS32
Part Number – 36112284655
Sounds like these should be fine then.
Fronts
Width - 10J
Offset – IS40
Rears
Width – 10.5J
Offset - IS32
sid10
Hi you need to check the PCD on the wheels if they are 611M winter square set up from the X5M , I read they used a different set up back to front like the X6 E71 74.1 fronts , 72.6 rears . Could be a costly mistake !
The latest X5 run 74.1 all round , just like the E70 .
Dogzyboy
[quote="sid10"]
Hmmmn. Thanks for pointing that out, I had best do some more research first. Cheers.
