Transmission issue
Al4693
Transmission issue
Post by Al4693 » Tue Nov 28, 2017 10:51 pm
My 2005 3.0d E53 auto is making rumbling noises in 1st and 2nd gears and also thuds and thumps before changing into 3rd when all then becomes normal. In addition in 1st when pulling away the car pulls strongly to the left. I am at a loss to understand whether this is an autobox or transfer case fault. Does anybody have any ideas please?
Re: Transmission issue
Post by X5Sport » Wed Nov 29, 2017 7:26 pm
First :hi:
Second it sounds like you need to get it into either a BMW Dealership, or Independant that can read the error codes to see what is recorded.  That will point you at the right place to look.  Not all errors throw a warning light.
If not then kkx5 is our resident transmission expert and may be able to give you a clue from your description of symptoms.
Al4693
Post by Al4693 » Wed Nov 29, 2017 7:33 pm
Many thanks X5Sport! We did plug and note that a transfer case fault was showing. I do have it booked in with an Independant.
Al4693
Post by Al4693 » Wed Nov 29, 2017 7:36 pm
Plug IN that should read! ... :-[
kkx5
Post by kkx5 » Thu Nov 30, 2017 9:18 pm
Fuse 46 out and test drive it.
X5-D-Sport
Post by X5-D-Sport » Fri Dec 01, 2017 1:47 pm
what does fuse 46 do ?
kkx5
Post by kkx5 » Fri Dec 01, 2017 4:17 pm
Fuse 46 switches off xdrive system.
X5-D-Sport
Post by X5-D-Sport » Fri Dec 01, 2017 5:25 pm
I presume X-Drive is the center diff lock ??
kkx5
Post by kkx5 » Sat Dec 02, 2017 9:14 am
Yes.
Post by henrym3 » Sat Dec 02, 2017 11:35 am
reading this you will forgive my ignorance but if you remove F46 does that turn the vehicle into a 2 wheel drive or make it into the previous system of being an "all wheel drive" but with no diff lock? :boom:
kkx5
Post by kkx5 » Sat Dec 02, 2017 9:19 pm
2 wheel drive only, Rwd. All power goes 100% to rear wheels, no 4x4, no abs, no dsc.
Al4693
Post by Al4693 » Sun Dec 03, 2017 2:27 pm
That's very useful to know m, I shall try that - thanks Kkx5!
Al4693
Post by Al4693 » Sun Dec 03, 2017 3:34 pm
Yep, with the fuse removed the symptoms disappeared. Couple of questions arising - 1. is it ok for me to drive it like this for a short period accepting loss of abs etc. I'm thinking damage to the front dif or other parts. 2. Is this a full transfer case overhaul/replacement issue or will it be the actuator at fault?
Many thanks for the help.
Post by Horizon » Sun Dec 03, 2017 4:01 pm
KKX5 runs a garage in Lancashire that overhauls transfer boxes. Not too far from Cheshire. PM him for advice
Al4693
Post by Al4693 » Sun Dec 03, 2017 6:10 pm
Many thanks, I will do that.
