Break Linings Warning Icon
X5-D-Sport
Post by X5-D-Sport » Thu Jul 20, 2017 9:43 pm
Hi people.
I had a warning light come up, re break linings low..
So, all 4 corners changed & the light is still on...
Does it need to be turned off ?  I have an OBD diagnostic tool, which found not alerts or faults - re this light.
I also have the little 3 button plug-in unit that re-sets the service gauge, but cannot remember how to make it work, it just flashes a lot but does nothing when the buttons are pressed... is there a sequence to make it work, as I have just changed the oil & filter & need to re-set the service warning lights to zero again..
Any help welcomed.
AW8
Re: Break Linings Warning Icon
Post by AW8 » Thu Jul 20, 2017 9:57 pm
Did you replace the sensor (s).
Offside front and nearside right IIRC (or other diagonal). There are only 2 (one ach oposite corner). When the guilty pad wears down the aemsor on end of cable creates a circuit with the metal which turns on the warning lamp. I thought a new senor sorted it. Perhaps someone else can confirm.
Huxsta
Post by Huxsta » Thu Jul 20, 2017 10:08 pm
+1 for new sensors.
Post by X5Sport » Fri Jul 21, 2017 8:19 am
As above.  Once 'tripped' the sensor must be replaced and if you have done both ends then change both sensors.  They are not expensive from somewhere like ECP  :)
X5-D-Sport
Post by X5-D-Sport » Fri Jul 21, 2017 11:15 am
Many Thanks Gents....
New Sensors it is then.
