Sunroof drains
alan996
Sunroof drains
Post by alan996 » Fri Apr 21, 2017 5:07 pm
Wonderful rain the last few days meant a bit of a leak from the driver side sunroof side
I think the drain is blocked but i have no idea where it exits. There's lots of talk about squeezing and opening the exit. But for the life of me i cant find where the exit is.
I tried a strimmer cable down the drain from the roof end but no joy - tried both driver and passenger side but it didn't go down more than 6 inches (maybe it's too thick a cable)
Anyone got any pictures or directions as to where the front sunroof drains exit ??
Sent from my Pixel using Tapatalk
pcdee
Re: Sunroof drains
Post by pcdee » Fri Apr 21, 2017 10:34 pm
I do believe the drain is located under the chassis near the driver and passenger side doors.
I've herd compressed air does the trick.  I  was going to try it but my roof is stuck closed!
X5 E70 3.0D SE
alan996
Re: Sunroof drains
Post by alan996 » Sat Apr 22, 2017 6:50 am
And that's my problem.. I can't see them - it's all jacking points and a massive sea of black plastic.
I need a treasure map :)
jeepstertim
Re: Sunroof drains
Post by jeepstertim » Tue Apr 25, 2017 8:10 pm
I had a Passat with blocked drains, the fault was actually at the drain end as the rubber exit has a flap to stop muck going up, the exits were in the A post.
Compressed air on the Passat was not recommended as it blew the rubber drain tube of the drain and then you were buggered!
davetherave
Re: Sunroof drains
Post by davetherave » Wed May 03, 2017 10:13 pm
Had same issue few months back. Tried compressed air but still blocked. Got garage to take A pillar trim off and they found kink in drain tube. Unkinked and straightened tube, flushed with water to ensure drained correctly before reassembling.
