The coolant temp is only reaching 67 degrees C
I looked on real OEM and got the part number for the main thermostat, but couldn't find a number for the EGR thermostat, so there only seems to be one used on the BMW 3.0 engine, so I ordered one.
Whilst I had the engine covers off today I could see the top of the EGR cooler.
It wasn't set up the same as all the ones on YouTube, which I had been trawling looking for How To do videos.
I could see an electrical selenoid valve on the top of it, and where the thermostat normally lives in the outgoing coolant pipe, on mine the pipe just goes straight back into the main return hose.
Has anyone come across this system before.
On real OEM there seems to be a vacuum actuator fastened to the incoming port of the cooler.
I may need a couple of golf tees to do a modification, I'm going to fit the main coolant thermostat and monitor the temperature.
My MPG is shocking at 67 degrees, must be over fueling .
