Can you Lower the ride height on air suspension
- allforus
Is it possible to get the coding changed to lower the rear air suspension ride height I only need to get about 20 MM lower to change the angle the car tows my twin axle caravan
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
graemeX5
Re: Can you Lower the ride height on air suspension
If X5Sport doesn't know it may also be worth sending a pm to Jason at BW chiptune as I know he can do a lot of coding on the cars.
Graeme
Graeme
- snrbrtsn
It's also possible to get adjustable links to alter height
H&R do the links, easily fitted and adjusted
- allforus
I read about the links but not sure how that works will take a look under the rear end to see how the set up
Works
I'm not sure if I've asked the question on here before I know it may change the cars handling but I don't push it anyway and would much rather have the caravan towing sorted
Thanks for the info
Works
Thanks for the info
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
- jason@bwchiptune
- Contact:
You can use like are adjust in the software just have to watch out as these will lower them selfs further at motor way speeds
BW chiptune
Tuning BMWs since 1991
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW Ecus
0208 561 1818
07831 103030
Hayes
UB3 1BB
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
Hayes
UB3 1BB
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
