Satnav has removed itself!!
Silverback mike
What's that all about then folks? The satnav has binned itself. Doesn't even register on the home screen now!!! How do I re install that then? I think I've got the disc...
BMW F10 tree hugging 520d efficient dynamics. E53 X5 and Frankenstein TVR Chimaera that really wants to kill me...it will one day..
- CondorX5
Re: Satnav has removed itself!!
You could try resetting everything by disconnecting the battery and reconnecting -that resets the cars electronics, which seem to get in a right tizz as they get older!
However, I had no less than three replacement MKIV Satnavs under warranty at crazy prices (luckily not to me) as they did similar things - they do sadly just go faulty, I think the laser from memory, is the culprit. There are repair services online for them, or you can try a breakers or ebay or even sometimes on here, replacements are about £40-£60 used, obvously a risk they are knackered or will be soon. New prices are so mad no-one would consider them (over £1500) as the satnav is very dated and not even as useful as a Garmin or a TomTom.
Luckily the satnav unit is easy to access and replacement does NOT need coding to the car, unlike the E70 and upwards.
X5 2005 Le Mans Blue 4.8is
Silverback mike
Well....it came back but fails again after about 5 mins and jams. Not too worried as the phone and stereo works. I'll just get a tom tom and slap it on the windscreen I think!
The Mk4 system is a bit limited in what it can do and a modern screen mounted one will very likely offer more. I use a Garmin in mine, mainly for the DAB based traffic system which is updated at 30 sec intervals instead of the 30-mins that TMC can provide. That and the map updates are free!
