Software upgrade causing high fuel consumption?
UrbanFlow
Post by UrbanFlow » Wed Oct 26, 2016 8:50 am
Hi all,
3 weeks ago my 2007 X5 (3.0L Diesel) went into an official dealer (Vines of Guildford) for a software upgrade.
Since the upgrade I seem to be experiencing much higher diesel consumption. It's literally drinking the stuff!
On board computer shows that consumption is down from an average of 25mpg to just 20mpg - and the journeys are the same.
Any ideas if the upgrade could have caused it (does it remap the engine?) or how improve consumption again?
Best
UF
Current Rides:
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Steamyrotter
Re: Software upgrade causing high fuel consumption?
Post by Steamyrotter » Wed Oct 26, 2016 10:12 am
Anything can (and usually does) happen with these!!
I would suggest contacting the dealer that did it and explain the situation to see if they have come across that before??
I would also try disconnecting the battery for a few mins, and discharging the car.
Reconnect and try again!!
Sounds simply silly but has been known to sort many a problem out before!!
john_o
Post by john_o » Wed Oct 26, 2016 11:45 pm
Call the dealer and discuss. How many miles have you done?  Do you have carly app and dongle?
Fuel consumption is high during regen. I wonder if for some reason your car is regening now but wasnt before?
Sent from my SM-N910F using Tapatalk
Post by X5Sport » Thu Oct 27, 2016 6:06 pm
Regens should only happen every 300 miles or so.
