Was browsing as you do and found this
It goes through the things you should look at and gives a good explanation wrt when gearboxes "fail" after a fluid change
https://youtu.be/o690DovjDAc
Enjoy??
Good video that explains about auto box fluid and changes.
- Steamyrotter
Re: Good video that explains about auto box fluid and changes.
Great find and makes it pretty clear as to why grotty fluid replaced by new can cause so much grief.
The other thing I noted is that if the box/fluid is already bad then new fluid is very likely to tip it over the edge into needing a rebuild rather than making it better.
