Hi all,
Is there a way I can stop the passenger wing mirror from dropping down when I reverse the car?
It's so annoying, all I can see is the kerb !
Thanks in advance.
Wing mirror goes down when car is put in reverse gear
Sunnythered
Colin
Re: Wing mirror goes down when car is put in reverse gear
Goodmorning , the slide switch you use when ajusting left or right mirrors keep it a the right side
05 , 30d Le Mans Blue Sport
Sunnythered
Thanks that did the trick
cooa99
lol,
That reminded me of when I bought my X5 and put in in reverse to see the side mirror dip down.
I quickly got out of the car rushing to the other side to catch the mirror.
Current Cars BMW 2005 X5 3.0d ; Golf 2003 1.9 TDI for the High Miles Journey to work
Colin
sometimes its a good thing in tight space with high kerbs , its just a matter of thinking in advance if you need mirror up or down before you select R ..
I thought there was a way of setting just how far down it dipped too? I know mine was adjusted because it was too far down but I can't remember if it was something I was able to do, or the Dealer could do it.
Colin
setting might be something to do with seat memory , ajust where you want the mirror then do the memory thing , what you think ??
Sounds sort of familiar....
