Flaps behind kidney grill
Ricky
Post by Ricky » Sat Apr 02, 2016 2:14 am
Anyone know when the flaps behind the kidney grills should open up? I've noticed when after a long run and a fair bit of heat has built up its rather sluggish below 3k rpm then above that it goes like stink??? It's as if the intercooler is too hot. And even when the engine is pipping hot I get out with the car running but the flaps are still closed? Is that normal? Oh forgot to mention it's a 3.0sd    ;)
Re: Flaps behind kidney grill
Post by X5Sport » Sat Apr 02, 2016 12:07 pm
Depending upon the year they can be electric or airflow controlled.
Ricky
Post by Ricky » Sat Apr 02, 2016 1:34 pm
It's a 08 and pretty sure it's electric as there's a wire to it and you can't push the flaps open, there is definitely a noticeable lack of power below 3000rpm when she's built up a fair bit of temperature, especially if it's stopped and heat soak sets in, just really weird that it only affect lower rpm and above 3000rpm still normal! It's like driving a very old school big turbo  :)) nothing nothing then woooooosh
celica
Post by celica » Sat Apr 02, 2016 6:24 pm
I posted about these before
Mine doesn't have any!
Post by X5Sport » Sat Apr 02, 2016 6:37 pm
You also have two identical (I think) turbos, one of the reasons for the 40d was to use dissimilar turbos to get rid of the lag.
Are both your turbos OK?
Ricky
Post by Ricky » Sun Apr 03, 2016 2:27 am
Power delivery seems fine till a fair bit of heat sets in then I start noticing a fair difference, think i will need to have it looked at :(
Ricky
Post by Ricky » Wed May 25, 2016 12:11 am
Just a wee update, with the warmer weather the strange lack of power below 2.5k 3.0k was becoming more apparent. So it turns out the vacume pipe to the small turbo was perished, I'm presuming when it was getting hot under the bonnet the rubber hose became softer and didn't hold the pressure as it became softer with the heat. Had all the hoses replaced and happy days she's back to her rapid normal self!
