stupid question go easy on me!!
petershamu
ok here go's !!
i am driving along in D can i when moving shift into tiptronic and change gears or do i have to start of in manual.
im 45 and havent a clue!!
buzz
Re: stupid question go easy on me!!
when you push it across it goes into 'sport mode' auto.....push forward or back and you are in manual tiptronic.....
petershamu
but can i push it across when travelling??
AW8
- Lifer
Yes.
petershamu
thanks guys, not a clue!!
graemeX5
And also back into D after
All that will happen is the box shifts into the Sport/Steptronic mode and it usually changes down one gear (as long as you are below 100mph in 6th......)
The gears will then each be held until higher rpm...even to the red line....before shifting.
Moving the shifter in and out of Sport/Steptronic in motion is normal.
petershamu
cheers guys expect a few dumb questions from me!!
great forum, no one takes the mick if you dont know.
im an "expert" on some other forums and they are hell with newbies!
- Steamyrotter
The only dumb question is the one that is never asked...
Also..
Dont try putting it in reverse or park when driving...
Also..
- pvr
- Lifer
... or rolling.
We had a discussion some time back about the overheating of the gearbox if you left it in neutral when going down a hill or so.
That's a definite do not, unless the box has a 'coast' function, and I don't think that ever existed on any version before the F15. Coasting is a waste of time anyway as you use more fuel keeping then engine idling!
AW8
- Lifer
One minor bit clarification.....When driving long moving selector to left causes boxto enter sport mode whereby revs are higher before gear change. Moving back andforth then causes manual mode to engage with redlining unless changed up earlier. The box downshifts for you. If yiu go from sport to D it reverts to normal auto mode.
