Hey peeps,
How many litres do I need of coolant for my 2003 3.0d, does it need diluting? GSF website comes up with 1 litre bottle when I put my reg in..confused
And How do I flush it?
New Anti freeze and flush
Re: New Anti freeze and flush
Approx 8.5 litres capacity and it needs to be the right type to ensure correct corrosion inhibitors. Do not mix types as you can inadvertently trigger chemical reactions.
Dilution rate depends upon how cold you want it to freeze at. 50% mix is a good average for UK. If you can, use distilled water, not tap water or de-ionised water. That way you avoid lime scale.
Sunnythered
If I am flushing the whole system can I put the better red anti freeze in for better protection?
It depends upon the inhibitors & spec. Never seen one with 'red' across any of our BMWs.
Aluminium engines need 'blue' anti-freeze......which is what all ours have had......as it has the correct additives for alloy engines.
The colour is significant so I suspect the red is not suitable.
Copy of BMW TIS:
Approved anti-freezing and anti-corrosive agents
With the protection of the environment in mind, BMW has been filling all of its vehicles with nitrite- and amino-free
anti-freezing and anti-corrosive agents since mid-1986 as standard practice.
The use of anti-freezing and anti-corrosive agents that contain nitrites and amines is no longer permissible.
Trade name BMW part number Container size
BMW Antifreeze 81 22 9 407 454 1.5-litre can
BMW Antifreeze 81 22 9 407 455 60-litre barrel
BMW Antifreeze 81 22 9 407 456 205-litre barrel
BMW Antifreeze 81 22 9 407 755 Tanker (truck)
Trade name Manufacturer/Supplier
Addinol Antifreeze Super Addinol Lube Oil GmbH
Aral Antifreeze Extra Aral AG
AVIA Antifreeze APN AVIA Mineralöl AG
BMW Antifreeze BMW AG
BP anti-frost X 2270A BP Schmierstoff GmbH, Hamburg
Caltex CX Engine Coolant Caltex
Castrol ANIT-FREEZE NF Castrol International
Fridex G48 Velvena s.a.
Glacelf Plus Total
GlycoShell Shell International
Glyco Star Bremin Mineralöl GmbH & Co.
Glysantin G48-24 Engine Coolant UNICO Ltd.
Glysantin Protect Plus / G48 BASF
GUSOFROST LV 505 Chemische Industrielle Gesellschaft
Mobil Frostschutz 600 Mobil Schmierstoff GmbH
Havoline AFC (BD04) ChevronTexaco/Arteco
Mobil Frostschutz 600 ExxonMobil
OMV Kühlerfrostschutz OMV AG
Total Thermofreeze Plus Total
1.0 Requirements concerning engine coolant
Pure water is unsuitable as a coolant not just because of the lack of protection against freezing-up. Good functioning of the cooling system is only guaranteed once a suitable anti-freezing and anti-corrosive agent, or antifreeze for short, has been added.
The cooling system of BMW vehicles must only be filled with the anti-freezing and anti-corrosive agents approved for this purpose. The filling and maintenance instructions to be found in the Repair Instructions and operating
instructions must be observed. Antifreeze agents must meet the following requirements:
- They must guarantee operability of the cooling system in winter (anti-freezing protection by lowering the freezing point) and in summer (prevent boiling and boiling over of the coolant).
- They must protect metal components that come into contact with the coolant (grey cast iron, steel, aluminium alloy, brass, copper and solder) against corrosion and cavitation.
- They must be neutral with respect to rubber and plastic parts in the coolant circuit.
- They must guarantee the consistency of the above-mentioned quality criteria.
To create these coolant properties, the anti-freezing and anti-corrosive agents must be mixed to the correct ratio with water.
Prescribed mixture for coolant:
- 50 % antifreeze for anti-freezing protection down to -38 °C
The original coolant mixture poured into the cooling system at the factory has this antifreeze-to-water ratio.
If the proportion of antifreeze is less than 40 % (i.e. the water content is higher than 60 %), not only the degree of protection against freezing, but also protection against corrosion is reduced. When the water content is too high, this can lead to premature overheating in very hot weather or hot climates and as a consequence lead to coolant being ejected out of the system and damage to the engine through overheating. This means that it is essential that an anti-freezing and anti-corrosive agent is added even in the tropics. Too high a concentration, more than 55 %, leads to deterioration of the cooling properties (heat transfer) and protection against freezing-up is modified in the opposite direction, i.e. it also deteriorates. The amounts of antifreeze required for providing protection against freezing-up are stated as percentage figures on the containers. However, it is not only necessary to comply with the mixture ratio specified; the minimum requirements for the quality of the water must also be adhered to:
• Appearance: colourless, clear
• Sediment, without suspended matter
• pH value: 6.5-8.0
• Total hardness, max.: 20° dH (German hardness grade) or in new measuring unit:
• Total hardness, max.: 3.6 mmol Ca 2+/ ltr.
• Chloride content: max. 100 mg/ltr.
• Sulphate content: max. 100 mg/ltr.
Potable tap water usually fulfils these requirements. Local water utilities can provide information about the quality of the water they supply. If necessary, the water must be treated (e.g. softened) or distilled water must be used.
The quality of regenerated sea water (as found in the Gulf states) is inadequate! SBS
Coolant additives
BMW does not approve the use of coolant additives that e.g. provide additional protection against corrosion or are aimed at sealing hairline cracks.
Due to the poorer transfer of heat from the cylinder head to the coolant, this can lead to heat accumulation and hot spots , which in turn can lead to cylinder head gaskets burning through and cracking of the cylinder head .
We cannot provide warranty for any consequences and effects the use of such additives may have.
Change interval, changing and testing coolant, disposal, cleaning the cooling system Change interval, changing and testing coolant
Regular checks of the coolant composition as part of Inspection I and II. As the anti-corrosion characteristics of the coolant decrease with time, the change interval of 4 years (3 years for M-Power vehicles) must be observed. The antifreeze concentration in the coolant must be checked each year before the cold season begins. The composition of the coolant must also be checked after the coolant level has been topped up. An areometer or densimeter (antifreeze tester) is required for setting and checking the concentration. It is permissible to mix various brands of the approved agents.
Ongoing technical development means that the coolant does not need to be changed on the vehicles listed below.
- E65 from 09/2003
- E60, all models since market introduction
- E85 since market introduction
- Vehicles with Service interval indicator (SIA) with petrol engines from 03/2003
- Vehicles with Service interval indicator (SIA) with diesel engines from 09/2003
- M vehicles from 09/2003
Disposal
The instructions laid down in the safety data sheets published by the manufacturers of anti-freezing and anticorrosive agents and the statutory regulations of the individual countries must be complied with.
Cleaning the cooling system
If the cooling system is soiled, e.g. by oil residue etc., it may be necessary to clean the system with a suitable cleaner.
Copy of BMW TIS:
Glacelf Plus Total
• pH value: 6.5-8.0
Coolant additives
- E65 from 09/2003
Disposal
Sunnythered
Thanks for that mate, I returned the red and bought the blue anti freeze after reading that.
Thanks again
Thanks again
