Steerin Wheel retracting when ign off
X5-D-Sport
When I turn off the keys/engine/igniton, the steering wheel lifts UP...
Then when starting the car ot goes back to its memory setting location...FINE...
Im told that t should also retract toward the instrument cluster also, as well as raising up ?
Mine doesnt... can t be set to do this some how ?
The fore/aft movement does operate when I pull/push the lever... but not automatically when the keys are switched on/off...
What should it do ?
Any ideas ??
What should it do ?
Any ideas ??
- AVI-8
Re: Steerin Wheel retracting when ign off
Mine goes up but not in also
Current
1991 Porsche 911 Carrera 2
Raj
- Lifer
Only supposed to go up and down I think just to allow easier entry / exit.
Mine was the same, but newer models do retract as well.
X5-D-Sport
Many thanks.... it's doing what it's supposed to then...
x6edge
Mmm the wheel lifted and retracted on my 2003 X5 and does the same on my 2012 x6.
- kkx5
You can get it programmed so it will go up and in.
X5-D-Sport
excellent... is there away to set this as a user, or does it need a main dealer to rob me ?
- kkx5
Bmw Ncs expert or dealer, need to be coded to key.
