Tyre Pressure Possible slow Puncture
cameronrobyn
Post by cameronrobyn » Tue Jan 20, 2015 8:23 pm
My run flat indicator keeps popping up on my 2006  3.0d.
I checked the tyres last week and one was at 22psi (Normally 32 psi)
I put air in them again today and same again.
Is it that obvious, or is there something I am not aware of.  It has been exteremely cold here in Ipswich.
The indicator came on again when I came to work tonight.
Brake it gently (See what i did there)!  I need a new tyre, any recomandations!
Cheers as always Andy
sid10
Re: Tyre Pressure Possible slow Puncture
Post by sid10 » Tue Jan 20, 2015 9:11 pm
Hi get the tyre checked first maybe an issue with the rim , if it is punctured get it repaired if possible , it is highly recommended that you run both tread depth tyres on same axle aswell as the same make , so if you change one  possibly better to change them both at the same time .
  what size is it as sometimes people post them on here or do a wanted add you maybe lucky if it needs changed ! also could be a faulty sensor I had one going off once a week after new tyres fitted .
cameronrobyn
Post by cameronrobyn » Tue Jan 20, 2015 9:17 pm
cameronrobyn
Post by cameronrobyn » Tue Jan 20, 2015 10:34 pm
Cheers Sid,
Just checked it again and lost 2 PSI.
Probably have to get a new one, and opposite tyre.  Can you use run flats on the front and normal on the back.
Talking £300 each
storminmike
Post by storminmike » Thu Jan 22, 2015 7:41 pm
Have you considered corrosion on the bead wall of the rim?
Twice now I had the problem so a quick trip to a back street garage tyre place....wheel off, tyre off then span the wheel upside down with a sanding disk to polish it back smooth.....no more issues
Smeeagain
Post by Smeeagain » Thu Jan 22, 2015 8:38 pm
What about the valves?
sid10
Post by sid10 » Thu Jan 22, 2015 9:07 pm
Sorry no you have to run all run flats or normal tyres ! As the others said could be the rim sometimes they get some crap in between the tyre & the rim once tyre off they simply clean it off refit the tyre jobs a god one . What style of wheels have you on the car ? Are they BMW X6 wheels ?
storminmike
Post by storminmike » Thu Jan 22, 2015 10:14 pm
[quote="sid10"]
agreed
I've seen it before. Normally it never goes completely flat.....just looses the 10 psi over 1 or 2 days and settles at that value
I'd try that first with a new valve..... £10 tops befor you screw the sidewall in for good
